6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Several issues popping up
Old Feb 10, 2013 | 05:53 PM
UGA33's Avatar
UGA33
Originally Posted by asquared
Nc requires a yearly state inspection to renew registration. I don't think I could slide by w/ a delete. Also im pretty sure a delete would void my extended warranty.
You could just run a DOC/DPF delete pipe that bolts up to the factory stuff. Its literally 30-45 mins on and off. If you have to pull that once a year thats not bad. All dealers are different. You could feel them out on the issue. Some will work with you and help you out if they feel you arent abusing the truck.
Old Feb 10, 2013 | 10:11 PM
StanleyZ's Avatar
StanleyZ
I've had a 7.3L turbo and I have a 6.4L. I admit the 7.3L will last longer and get better economy, but have more power? Not a chance, not even close. If you can't modify the 6.4L I would suggest that a 06 or 07 6.0L would make a good choice. A lot less trouble than the eariler 6 liters and can be "bullet proofed" without breaking any federal laws. Just a thought.
Old Feb 11, 2013 | 04:49 PM
CKetchum's Avatar
CKetchum
I have a friend with an 08' 6.4L and his truck was going in and out of regen. The exhaust pressure sensor was the problem. It's one of the three in/around the DOC/DPF in the exhaust.
Dirty30
6.7L Power Stroke Diesel
Jul 6, 2019 04:01 PM
memacon
Jun 29, 2018 01:59 PM
davbeisner
Jun 19, 2016 03:17 PM
Brettboat
16
Nov 29, 2015 09:47 AM
Stephen67
Jul 6, 2012 02:13 PM
