Sponsored by: Real Truck
Flash to pass....
Old May 30, 2003 | 04:01 AM
RedTaurus94's Avatar
RedTaurus94
Flash to pass....
I noticed this morning when I came to work earlier than normal that my flash to pass doesn't work. The brights and the dims both work OK, just not the FTP. Anyone got any ideas as to what might be the problem? Fuse? Loose wire?
Guess I'll check it out when I get home. The sun will be up then.........
Old May 30, 2003 | 11:12 AM
cwb's Avatar
cwb
Flash to pass....
We have flash to pass on our trucks?
Old May 30, 2003 | 11:20 AM
warmdye's Avatar
warmdye
Flash to pass....
Old May 30, 2003 | 11:58 AM
Streetcruzer's Avatar
Streetcruzer
Flash to pass....
Well, I have a 2002 S/D and mine has it, This is when you pull up on your turnsignal lever and that will hold your lights on till you let the lever down in nuetral position. This will work when lights are on or off!! To answer the question, it is probbaly your switch
has gone bad,it would be easy to check if you know which wires coming out of switch send juice to the lights when you pull lever up and check with a meter! I have the same switch on my Sterling (Ford OTR Tractor) and will replace one every 6 months, which is roughly 60,000 miles. I am not sure of a fuse, but could be a unatached wire???
Hope this helps,
Lenny
Old May 30, 2003 | 01:58 PM
FortyFords's Avatar
FortyFords
Flash to pass....
chk fuse 7.,and fuse 30
These protect that circuit
Rich
Old May 30, 2003 | 08:53 PM
jetjock16's Avatar
jetjock16
Flash to pass....
dude, if you have to flash people for them to get out of your way you need to get a bigger lift and wider tires... people shove over to the shoulder when they see me coming, even dudes in the other lane, opposite direction edge towards the side, they wouldnt want to get run over....he he he.. i havent had to flash anyone yet, they move....
Jetjock16
Old May 31, 2003 | 09:28 AM
FortyFords's Avatar
FortyFords
Flash to pass....
JetJock ,
Not everyone likes lifted trucks!
To each his or her own !
Oh! I forgot your from Texas!! He he he !
RedTaurus ,Did you find the problem?
Rich
Old May 31, 2003 | 10:04 AM
RedTaurus94
Flash to pass....
Haven't had a chance to look yet, actually. But, I will today sometime, I hope. My son had a baseball game yesterday evening and it's raining some here this moning. I'll look at them after while.
I wasn't trying to actually get someone to move over when I noticed the problem. I was just wanting to see the effect of having the brights and dims on at the same time. My truck is a 2000, and the brights aren't really as bright as I would like them to be. Man, hose headlights on my brother-in-law's 2003 sure do look good. Wish I had available capital to make that switch.........
Old May 31, 2003 | 01:01 PM
nafzimo's Avatar
nafzimo
Flash to pass....
I prefer the air horn to pass method.
Old May 31, 2003 | 02:16 PM
jetjock16's Avatar
jetjock16
Flash to pass....
Hey Red.. for real i didnt think my brights were bright enough either.... so i read the threads on how to wire the fog lights to stay on when you have your brights on, it makes a big difference.(from the factory your fogs can be on, but when you got to brights they turn off!) try that and ill be youll be happy with your brights then......
Jetjock16
Old May 31, 2003 | 05:35 PM
Outpost22's Avatar
Outpost22
Flash to pass....
Pass 'em???? I just run OVER 'em
Old May 31, 2003 | 07:40 PM
Bordaine's Avatar
Bordaine
Flash to pass....
Please note
BIG stainless steel brush gaurd works just as good as ftp lights
Steve
Old May 31, 2003 | 11:11 PM
RedTaurus94
Flash to pass....
Jetjock, unfortunately I don't have the fog lights. I love the way they look though, and I wanna get some as soon as I can. I just remembered reading that the BrightBox thingamajigger caused both the dims and the brights to be on at the same time, so I just wanted to see what it would look like. It is usually daylight by the time I go into work, and on Friday, I went in real early whilst it was still dark.
Anyways, here's a report on what I have discovered:
I decided to check fuses 7 and 30, like FortyFords suggested. I raised the hood and popped off the fusebox cover (P/N F65B-14A003-C, in case you're interested), and proceeded to evaluate my fuses. In this box, I noticed 2 diodes, 6 relays, and only 29 fuse locations (I have no fuses in #s 15, 16 & 28). Number 7 looked good, and since there was no #30, I reinstalled the cover, and went inside the cab. There, I removed the panel from underneath the steering column (panel P/N F81B-25044F08-AEW, if ya wanted to know). I popped off that fusebox cover, and saw 5 relays and 31 fuse locations (no fuses in #s 5, 6, 9, 10, 17, 18, 21, 23, 25, 26 & 31 for me). I looked at both #7 and #30, and both were good. I also noticed that Ford had placed a handy-dandy fuse removal tool on the inside of the fusebox cover. I thought that was right neighborly of them. While I was in there, I decided to check out the wiring coming out of the steering column. There is one large group of wires that comes out of the column, containing 8 smaller wires. Two of them, one gray with an orange tracer, the other gray with a white tracer, go to a single plug. The other 6 go to another plug, in two rows of three connections. From left to right across the top was a solid black wire, a blue w/ red tracer, and a blue w/ black tracer. The three wires across the bottom of that plug are a black with a fuschia tracer, a green w/ orange tracer, and a solid blue wire. I noticed that my black wire with the fuschia-colored tracer was broken completely into. I speculate that this may be my problem, but I wanted to consult with the experts on here before I reconnect anything. Actually, I didn't have time to work on it as my son had another baseball game this evening! Really, the only thing that I see that is not working is the flash to pass, so I didn't want to jump in without finding out if someone else has knowledge about what all these wires are for.
ANYWAYS.....sorry this post was so long. I just love tinkering with my truck, and I wanted to share the details with you all. Knowing that I have yous guys to discuss these matters with makes it that much more fun!!! Lemme know what y'all think.........
Old Jun 1, 2003 | 12:23 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Flash to pass....
Oh man, I was following along nicely until the word fuschia popped up . I found some wires with pink tracers........
but seriously...
Assuming I'm reading the wiring diagram correctly, the FTP jumper is intergral to the multifunction switch. The four wires from the multifunction switch are dark blue/orange in and gray/orange out on the constant hot side, and red/yellow in and red/black out on the switched power side.
I did not see a black/pink (or fuschia) wire anywhere in the headlights wiring diagram.
Old Jun 1, 2003 | 07:58 AM
FortyFords's Avatar
FortyFords
Flash to pass....
This truck doesn't have daytime running lamps or auto lamps does it ?
It could get real confusing if it does!
Fuse # 7 (30amp) main light switch
You should have 12volts on gray/org and rd/blk when hold ftp switch in that pos.
Gray /org wire feeds fuse #30 (15amps) circuit changes to lightgreen/blk wire and continues on to low beams/ both headlights .
The rd/blk wire feeds fuse #46 and fuse #47 both are 10amps then cicuit changes to Darkbrown /white wire off fuse 46 to your left headlamp high beam and from fuse 47 on a dark green/organe wire to your right headlight.
But if you drl or auto lamps will start over Rich
Cookie 88
gave you the wires going to the switch and coming out of it .
I just gave you where they go after the FTP
switch
Rich
