97 Powerstroke 5 speed PCM
Old 02-09-2013, 10:21 AM
97powerstrokemaniac's Avatar
97powerstrokemaniac
97powerstrokemaniac is offline
Exclamation 97 Powerstroke 5 speed PCM
I know this is not a classified forum but I am in desperate need of a 97 5 speed PCM. Any help is appreicated
Old 02-09-2013, 12:31 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Any 5spd. manual PCMs from '94.5 to '97 will work, or if you have an auto PCM you can get it flashed to a manual. I don't have any, but I hope this helps.
Old 02-09-2013, 02:54 PM
97powerstrokemaniac
I put one in that says made in 7/95 and it doesnt
Old 02-09-2013, 04:07 PM
fordpride's Avatar
fordpride
fordpride is offline
What's your issue ? It may not be the PCM
Old 02-09-2013, 04:44 PM
96ford250's Avatar
96ford250
96ford250 is offline
I have a 96 PCM for a 5spd but its from a gas engine could it still get reflashed? I mean something is better then nothing.
Old 02-09-2013, 05:15 PM
fordpride's Avatar
fordpride
The pin out would be different
Old 02-09-2013, 05:37 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
X2 ^^^^^^^^^^
Old 02-09-2013, 07:22 PM
96ford250's Avatar
96ford250
O well I tried haha thought it was worth a shot
Old 02-09-2013, 07:36 PM
97powerstrokemaniac
the problem is that i did a five speed swap, got the manual harness that runs down to the tranny switched the correct pins, checked all fuses and it will just turn over forever and not fire or act like it wants to fire. No WTS light comes on either. Auto PCM is GONE.
Old 02-09-2013, 07:48 PM
fordpride's Avatar
fordpride
No WTS means mo power to PCM. Check fuse #22 under the hood.
For the no turn over did you deal with the clutch safety switch under the dash
Old 02-10-2013, 08:41 AM
97powerstrokemaniac
it turns over
Old 02-10-2013, 09:59 AM
444dieselrod's Avatar
444dieselrod
444dieselrod is offline
An auto PCM will work in a pinch, then just lope at idle when you first start it.
Diesel Rod
Old 02-10-2013, 03:36 PM
J.N.'s Avatar
J.N.
J.N. is offline
I agree with FordPride and ReBilld it may not be the PCM. I didnt hook up the clutch safty switch and am running my Auto PCM that was in my truck before i did the swap with no issues of lopeing so far. It very well could be the fuse that FordPride is talking about. Just to throw it out there my Injector control module went out on me a while back over night. Cranked fine the day before and the next day just would roll over.
Old 02-10-2013, 04:05 PM
fordpride's Avatar
fordpride
When you put the PCM in was the batteries dissconected?
Old 02-10-2013, 06:26 PM
97powerstrokemaniac
Yes batteries were disconnected and I checked all the fuses. The 95 PCM should be compatible right?
Quick Reply: 97 Powerstroke 5 speed PCM
