Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
awd problem
Old Feb 8, 2013 | 07:28 PM
findingmyway's Avatar
findingmyway
awd problem
I have a 2005 awd...the awd isn't working...when i bought the escape i had tried to get it to work and it did and the light came on flashing 4x4...a few weeks later there was a noise coming from the rear end...nothing to do with my test ...i took it to the dealers mechanic and was told they would fix it and as far as i know they did...no noise...after i checked again, the awd is not working...i didn't check till months later...it's snowing here and found out it's not working....i am thinking maybe they disconnected it some how instead of fixing it....any opinion on this would be appreciated ...can it be disconnected ? what would they do to do that or why wouldn't it be working ?...thanks
Old Feb 8, 2013 | 09:57 PM
wptski's Avatar
wptski
What do you mean by tried it and it's not working?
Old Feb 9, 2013 | 04:47 PM
findingmyway
the wife was driving i got out and watched the wheels...when she step on the gas in the snow the front wheels spun but the backs ones didn't...
Old Feb 9, 2013 | 10:14 PM
wptski's Avatar
wptski
It's unlikely they could defeat it without you getting an dash icon alert. There are one or two fuses but then again you'd get a dash icon.
You could have your wife move it slowly to see if the driveshaft is rotating, it should rotate all the time.
Old Feb 12, 2013 | 12:32 PM
findingmyway
ok then anyone know what could cause this to happen? how can something work and then not?..is there maybe an electronic problem? also i have noticed at times the truck rolls back on a hill if i let go of the brake peddle...the truck is an auto matic...and not just a few inches back i let it roll one day and it rolled back about 3 car lengths and then i stopped it...
Old Feb 12, 2013 | 01:48 PM
wptski's Avatar
wptski
If it was electrical, you "should" have a dash icon come ON. If the driveshaft isn't rotating then no power to the rear wheels.
You can check the fuses, #18 and #35 on the inside fuse panel. Under the hood #19. All three mention 4WD.
dannielchackas
Dec 17, 2008 01:43 PM
baitmaster
2004 - 2008 F150
May 2, 2007 08:47 PM
FredMez
Oct 1, 2003 07:38 AM
RDMoore
Aerostar
Dec 31, 2002 07:16 PM
