Transmission Fluid Level
Old Feb 8, 2013 | 06:29 PM
SammyBoy's Avatar
SammyBoy
Hello All,
I have a 2006 F150 5.4l 4x4. When the engine is running and even when at normal operating temps., my trans dipstick in below the last bar showing a drip of fluid...however as soon as turn the motor off, the reading is normal?? Is this how it's suppose to work?
Old Feb 8, 2013 | 08:27 PM
JWC 3's Avatar
JWC 3
Originally Posted by SammyBoy
Hello All,
Sorry , but no . Read your manual . Check fluid with engine running , trans in park . Cold mark , hot mark . If just touching while running , you are low . When the engine is off the pump stops , fluid drains into the pan . When running , pump is working and circulating fluid . Running is when you need to check it . Use the proper fluid for your trans .
Old Feb 8, 2013 | 08:30 PM
pepito113's Avatar
pepito113
I believe that the right way to check it is to warm up the transmission fluid. It takes a few miles to heat up. so Drive it around town 10-15 miles.. Then with the truck running you check the fluid. On a cold day it can take a while of driving to warm up. So go for a long drive and check it with the truck running..
Budman1962
Jul 29, 2013 06:26 PM
pablocruz69
Jun 2, 2011 11:53 AM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
Aug 11, 2008 08:38 AM
UGA33
Aug 8, 2008 11:51 PM
monty0
Nov 6, 2006 09:29 PM
