Will this work??
Old Feb 8, 2013 | 02:50 PM
Blacksnake's Avatar
Blacksnake
Will this work??
i am looking for a 460 Bell housing to use on an engine run stand. I found one on craigslist, it says for a 351M or 400, I researched and found that will work for 460.................then i may have over researched and some say no
WHich is it? THe cast number is D97A-7505 per the add
Ford 351m" bell housing
Thanks Ryan
Old Feb 8, 2013 | 03:36 PM
rustywheel68's Avatar
rustywheel68
Yes, the 351M is the same pattern as the 460.
List of Ford bellhousing patterns - Wikipedia, the free encyclopedia
Whether or not the bellhousing in your ad is actually from a 351M...no idea.
Old Feb 8, 2013 | 04:39 PM
jowilker's Avatar
jowilker
Ryan, There are 3 basic bells of this era, a round top for the FE 352-390, flat top 5 1/2" bolt pattern 302, 351W, 300 six, flat top 7 1/2" spread 351M 429, 460.
Appears that you should be good to go.
John
Old Feb 8, 2013 | 05:08 PM
Blacksnake's Avatar
Blacksnake
One of the guys on the 460 forum said based on the picture in the add that one is a SBF bolt pattern? Can someone confirm?
Ryan
Old Feb 8, 2013 | 05:31 PM
rustywheel68
you'd be better off asking that question in the 335/385 series engine forum- i think its safe to say almost no one in this forum is running a M-series engine.
or as Jowilker said, you could just measure it.
personally, i never trust myself- when i look at transmissions, i carry a block/bellhousing spacer plate with me and make sure everything lines up.
Old Feb 8, 2013 | 05:47 PM
kenny nunez's Avatar
kenny nunez
bellhousing
Black snake, Just be sure that you also get the dust shield that locates the starter correctly and also the correct flywheel as later 460s were externally balanced. I know for sure that a "M" series bellhousing mounts to a 460.
Kenny
Old Feb 8, 2013 | 06:00 PM
rtowing's Avatar
rtowing
i didnt know or have seen three bells c4 or c6 i wold like to see the difference my self as i run a 429 in my 68 with a c6 bm tranny
Old Feb 8, 2013 | 07:43 PM
willowbilly3's Avatar
willowbilly3
FE flywheel should work too. 78 and earlier engine anyway, don't know about the later 460s.
Old Feb 9, 2013 | 05:42 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Which is it? The cast number is D97A-7505- per the ad Ford 351m" bell housing
No such ID/casting number, it should be D9TA-7505-? But, the suffix is missing, so there's no way to ID it. And, be aware that there are TWO different F100/350/Bronco 351M/400 bellhousings.
The difference has to do with the clutch fork, clutch fork ball pivot, clutch release rod (pedal to Z bar) and the Z bar itself. These parts are specific to one or the other.
Ford bellhousing part numbers: D7TZ-7505-A = 1977/78 and 1979 351M/400 before serial number DG0,001 / D9TZ-7505-B = 1979 351M/400 from serial number DG0,001 & 1980/82.
ALL 1968/82 460's came w/a C6. 1983 was the first year the 460 was available w/a manual trans (and 4WD). All 1983/97 460's came w/a hydraulic clutch.
Originally Posted by willowbilly
FE flywheel will work. 78 and earlier [460] engine anyway.
Incorrect, the 460 engine changed mid-model year 1979, not in 1978.
1971/73 429, 1971/78 460 & some 1979 460's: The block casting number is D1VE-6015-AB
Mid-model year 1979, 1980 and later: The block casting number is D9TE-6015-AB .. has a weighted spacer.
The 1979/97 flexplate, 1983/97 flywheel & 1979/97 harmonic balancer are specific to this casting number.
1979: This was a "running change" so, there are no before/from serial numbers/production dates to go by.
Old Feb 9, 2013 | 06:17 AM
jowilker's Avatar
jowilker
Ryan
Ryan I didn't look at your link yesterday, It is indeed a small block. NO GO.
The top holes are 2in. further apart on what you want.
John
Old Feb 9, 2013 | 07:30 AM
willowbilly3
Ford bellhousing part numbers: D7TZ-7505-A = 1977/78 and 1979 before serial number DG0,001 / D9TZ-7505-B = 1979 from serial number DG0,001 & 1980/82.
I said 78 and earlier, didn't want to confuse the guy with mid year change 79 stuff that I didn't have the particulars on, just keep it safe.. You know, I'm just an old seat of the pants junk yard crawler who has learned most of what I know the hard way and before computers. Sorry if that annoys your **** self there ND.
Old Feb 9, 2013 | 10:08 AM
Blacksnake's Avatar
Blacksnake
thanks
Thanks everyone, i will keep looking. As John said from the picture it is a no go, SBF. THanks again
anybody got one ? lol
Ryan
Old Feb 9, 2013 | 01:25 PM
kenny nunez
bellhouslng
Blacksnake, I live in the NewOrleans area, I have the bellhousing,dust shield, flywheel for an early 460 for internal balance and the clutch fork. Also t he complete clutch linkage. 504 469 2320h 504 427 6905
Kenny
Old Feb 9, 2013 | 05:09 PM
Blacksnake's Avatar
Blacksnake
All i really need is the bell housing, I have everything else, since I just need it for a run stand, is it cast iron or aluminum, prob be costly to ship? What do u need for it?
Old Feb 10, 2013 | 12:54 PM
kenny nunez
bellhousing
Blacksnake, The bellhousing is cast iron , but i would only sell the whole set up. I even have the pedals for the manual transmisson. Hopefully someone out there will have what you need. Good luck , Kenny
