fuel door
Old Feb 8, 2013 | 08:00 AM
cappo's Avatar
cappo
fuel door
Was wondering if someone can advise how to remove the fuel filler door on a 1999 E150 Cargo van. I did a search on this topic but came up empty. Thanks
Old Feb 10, 2013 | 07:23 AM
JWA's Avatar
JWA
This door is held to the body by two threaded fasteners visible when the door is opened when refueling. Its a hinged assembly and the visible disc can't be removed separately.
At least that's the way it is on my '97, '00 & 03!
Old Feb 10, 2013 | 07:44 AM
cappo's Avatar
cappo
Thank you JWA I will check it out
Old Feb 11, 2013 | 04:34 AM
JWA's Avatar
JWA
I can take a picture of mine if that would be helpful.
Old Feb 11, 2013 | 12:19 PM
cappo's Avatar
cappo
Thanks JWA but I did get it off. Appreciate your help!!
Old Feb 11, 2013 | 10:03 PM
maples01's Avatar
maples01
I took mine off and put on a chromed aluminum one designed for the trucks, when that fad was popular, it was straight forward, 2 bolts hold the swing bracket to the body.
Old Feb 12, 2013 | 05:25 AM
JWA's Avatar
JWA
Send me some reps then!
Glad that worked out for you---sometimes these things are either more or less complex than we first think. Can't recall the number of times I'd have saved myself hours and hours by just asking in advance!
Old Feb 12, 2013 | 07:13 AM
cappo's Avatar
cappo
I guess the simplicity of it fooled me. I had to remove the fuel door on my Dodge Caravan and had to remove everything but the engine to do it...hah!!
A rep. is headed your way. thank you
Trask55
Dec 17, 2021 01:15 PM
Wbruiser2
1997 - 2003 F150
Sep 27, 2018 05:22 AM
5.0Torx
2009 - 2014 F150
Oct 25, 2015 09:41 AM
bcrab
2004 - 2008 F150
May 16, 2008 12:11 PM
eff15thtee
2004 - 2008 F150
Dec 27, 2006 07:57 PM
