Front end issues
Old Feb 9, 2013 | 06:23 PM
labman1014's Avatar
labman1014
Might fix the sides but where the grille meets the headlight there will be a gap at the bottom.
Old Feb 9, 2013 | 09:51 PM
Apocalypse's Avatar
Apocalypse
Oh yeah
Well onto another issue, the hood and grille gap. The header panel is only held on by 4 bolts, 2 on each side. Is that right? I can lift it (It's pretty flexible) about half an inch and the hood and grille line up perfect. Am I missing screws or what?!?
Old Feb 9, 2013 | 10:45 PM
EXv10's Avatar
EXv10
Sounds like screws are the least of your worries. I would sell what doesn't fit and start over.
Old Feb 9, 2013 | 11:44 PM
Apocalypse's Avatar
Apocalypse
Well I'm thinking if I can make the grille and headlights work I can have my buddy fab up a heavy duty bumper Just have to get the top half right first.
Old Feb 10, 2013 | 06:56 AM
saz2686's Avatar
saz2686
It doesn't look terrible. Better than the old look I think.
Old Feb 10, 2013 | 01:40 PM
Apocalypse's Avatar
Apocalypse
Are you not seeing the gaps bigger than the one at the mall?!? (The Gap store in case you didn't get that)
Old Feb 12, 2013 | 05:08 PM
Apocalypse's Avatar
Apocalypse
Back up, need to get this thing back together
Old Feb 14, 2013 | 07:32 AM
Apocalypse's Avatar
Apocalypse
Come on guys, I know someone can chime in with some help
Old Feb 14, 2013 | 03:59 PM
labman1014's Avatar
labman1014
Do u have the limited flares on ur Ex?
Old Feb 14, 2013 | 07:57 PM
Apocalypse's Avatar
Apocalypse
I have an 02 limited... Do I need to buy flares for an 05+?
Old Feb 14, 2013 | 08:09 PM
sammie0126's Avatar
sammie0126
Originally Posted by EXv10
Sammie might chime in with some pointers.
Well been kind of MIA for the last week with work. But I installed and O5 grill on mine no fitment issues whatsoever bolted right up no gaps also replaced headlights but mine are Eagle Eye lights.
Old Feb 14, 2013 | 09:03 PM
labman1014's Avatar
labman1014
No should be the same. My only guess would be another bumper and top pad.
Old Feb 15, 2013 | 11:32 AM
  #28
Apocalypse's Avatar
Apocalypse
That's what I'm thinking Really was hoping that that wasn't it... sigh.
Old Feb 15, 2013 | 12:14 PM
  #29
labman1014's Avatar
labman1014
There is an 07 on a lot here. If I get a chance I'll stop and take some pics for u.
Old Feb 15, 2013 | 12:28 PM
  #30
jeeplj8's Avatar
jeeplj8
Bumper problem - the plastics on your bumper were designed to go with a larger fender flare. Chances are the Super Duty had larger flares in 05, the 05 Excursion bumper is probably a one off to work with Ex flares.
Headlights/grill gap - the headlights look they are designed for the hood to sit lower than the fenders, but of course yours does not. they just don't look right. I would just fill that gap on each side with some plastic. As to the grill, you should be able to move the grill up a little where it mounts to the header. how is the gap between the grill and the bumper?
I hate to say this, but I don't think your header is square. It could be your truck has a little front end tweak from an accident, but more likely you are just not getting it sqaure installing it.
