4wd pulls to the right
Old Feb 7, 2013 | 08:35 AM
run6.0run's Avatar
run6.0run
I will post this in the sd side also,, but we got a great network here also. But when I lock the hubs in, no matter if I'm in 2 or 4wd, my truck pulls to the right. It doesn't do it when the hubs are in auto. I had the pass side hub sticking so I replaced it. My PVH is bad also,,, I finally vac'ed it down at the PVH to the front axle n it holds vacuum. Ball joints are tight along with steering. However, I haven't done the wheel bearing test with the tool it calls for (but I'm sure I could rig something up to measure the wobble). But by hand they feel good.
Could this be a prob with the front diff??
Old Feb 8, 2013 | 05:07 AM
Yahiko's Avatar
Yahiko
Did you check the condition of the lube yet? The pull tells me that something is dragging
with the hub is locked. Try locking it and hand spinning the wheel and see it there is
more loading on one side.
Sean
weatherproofer
Mar 27, 2017 07:26 PM
run6.0run
Feb 11, 2013 03:48 PM
run6.0run
Feb 11, 2012 09:16 PM
C-TAN
Apr 30, 2010 03:44 PM
fred l
1983 - 2012 Ranger & B-Series
Nov 15, 2008 01:49 PM
