C1095 code
Old Feb 5, 2013 | 03:53 PM
pyro2nite's Avatar
pyro2nite
C1095 code
The ABS light came on, so I checked the code. Got a C1095, Hydraulic Pump Motor Failure. Checked all fuses and then did the pin test as outlined on another form. I found that I was not getting any power to the plug leading to the hydraulic motor. Maybe I missed a fuse? If the motor is in fact dead, there still should be current running into it?
1998 Ranger 4X4
Thanks
Old Feb 5, 2013 | 11:22 PM
pawpaw's Avatar
pawpaw
Here is a link to a pinpoint test for this problem. What do i look for to fix a code c1095 in my 2003 explorer - JustAnswer
Old Feb 6, 2013 | 09:49 AM
pyro2nite's Avatar
pyro2nite
Thanks much................I don't have the required scan tool. I did a Google search and ran across that one already. I checked with a volt meter and best I can tell, there is no voltage to the top pin.
Old Feb 6, 2013 | 10:47 AM
pawpaw's Avatar
pawpaw
OK, well maybe consider running this puppy by a trusted brake shop & have them put their scantool on the ABS ststem & see what they think.
Old Feb 6, 2013 | 03:50 PM
pyro2nite's Avatar
pyro2nite
Thanks for the tip. What did you find with your truck?
Old Feb 6, 2013 | 04:17 PM
pawpaw's Avatar
pawpaw
I've never had an ABS problem with my Ranger. Did your problem come about after some event????
Old Feb 6, 2013 | 04:19 PM
pyro2nite's Avatar
pyro2nite
No event.............
Old Feb 6, 2013 | 04:46 PM
pawpaw's Avatar
pawpaw
OK, no event, so begin with step one in the pinpoint testing & let us know what you find. Maybe first look for the obvious, like damged wiring or insulation, loose electrical connectors, or corroded pins/sockets, bent pins, spread sockets, so do a wiggle & or thump tests & see if the problem/code clears.
With the ABS motor not getting power, you won't have ABS, but your normal braking is unaffected, so be careful on slick surfaces until you get this put right & let us know how your trouble shoot goes..
OCMetalhead
Escape & Escape Hybrid
Dec 31, 2016 08:16 PM
mfp4073
Feb 25, 2016 05:10 PM
whiteaddiction
Sep 15, 2009 12:20 AM
nocal
Jun 13, 2004 06:48 PM
