Power Locks Unlock Themselves
Old Feb 5, 2013 | 02:54 PM
SP07SCrew's Avatar
SP07SCrew
Hi everyone
I have a 2007 f150 SCrew XLT
The problem I've been having for awhile is that the locks unlock themselves. I first noticed it when I came out in the morning and the truck was unlocked and I was pretty sure I have locked it the night before, then over time it started to unlock itself while I was driving - over and over again with no input from me with fobs or switches or anything. It doesn't matter whether the truck is running or not, keys in or out it unlocks itself randomly and often
To be clear, the locks do not cycle lock and unlock, they ONLY do the unlock action. When you drive down the road it sounds like someone is pressing the unlock button over and over again - sometimes rapid fire... then sometimes 20 minutes goes by without a problem
Originally I thought the problem was worse when it was raining which it might have been
I took it to the dealer and explained the problem, they said that the windshield and rear cab light were leaking making the module wet and if we fixed the leaks and dried it out it should work fine again
Fixed the leaks, confirmed that it was staying dry - same problem
Then they tell me the body control module must be fried so I need a new one - they replace that. The problem remains
I took it back to the dealer and said I didn't want the truck back until it was fixed. They claim to have inspected all the wires running in and out of the BCM and can't find any issues. The problem remains
Sorry for the long story
I need this thing to stay locked and the dealer clearly does not know how to fix it. Any suggestions are appreciated
Thanks in advance
Steve
Old Feb 6, 2013 | 01:09 AM
papasmurf40's Avatar
papasmurf40
Best solution i can add is maybe an exorsism.....
Old Feb 6, 2013 | 05:20 AM
ojai150's Avatar
ojai150
have you tried opening the door with a key,..and leave the remote fob at home, and see if it still does it...
Old Feb 6, 2013 | 10:26 AM
SP07SCrew's Avatar
SP07SCrew
Hi thanks for the replies,
Yes, I've taken the fobs out of the equation as well as have them re-programmed. The only way to keep this thing locked seems to be pulling the door lock fuse and then it is very difficult to get the back doors open!
I'm exploring the exorcism in a different forum
Old Mar 7, 2013 | 07:49 PM
SP07SCrew's Avatar
SP07SCrew
Looks like the actual problem was a faulty lock/unlock switch on the drivers door... something I suggested a couple months ago
Thanks for the suggestions
Old Mar 7, 2013 | 10:16 PM
gijim2k1's Avatar
gijim2k1
I was going to say gremlins, but I'm glad you figured it out.
trike1946
Electrical Systems/Wiring
Feb 21, 2019 03:48 PM
Vanaddiction
17
Feb 26, 2014 07:07 PM
massteen94
1997 - 2003 F150
Feb 10, 2011 08:06 PM
propguy
Jul 16, 2007 10:43 PM
TTFord07
Jul 9, 2007 12:20 AM
