Blower motor
Old Feb 5, 2013 | 01:46 PM
afran's Avatar
afran
Blower motor
My blower motor will not come on. If I put power directly to the motor, it will spin. I believe it is something electrical. Any ideas where to start? Thanks
1989 F250 4x4 with 460 manual
Old Feb 5, 2013 | 03:02 PM
Freightrain's Avatar
Freightrain
It doesn't come on even in "HI" position? Then I'd start to look at power? Fuse? Then check switch to see if you have power at switch. The resistors for speed control should not come into play in "HI".
Old Feb 5, 2013 | 03:09 PM
afran's Avatar
afran
Sorry, should have been more clear. It doesn't come on at all. I checked the fuse, and it is good. I guess the next step is to pull the unit and start probing. I just was hoping for a quick easy fix . So much for wishful thinking
Old Feb 5, 2013 | 06:16 PM
F150xlt's Avatar
F150xlt
Here's the schematic for a 88. Can't say for sure the 89 has the
same wire color code.
Old Feb 5, 2013 | 07:38 PM
afran's Avatar
afran
Thanks a ton!!! This is great!
railbag
1997 - 2003 F150
Nov 7, 2010 07:52 PM
senix
Jan 21, 2010 09:34 AM
jimsexplorer
Jun 16, 2009 07:01 AM
can87f15
Oct 16, 2008 08:12 PM
blackf3504dr
Jan 22, 2005 06:08 AM
