replacement/ upgraded stering pump?
Old Feb 4, 2013 | 08:19 PM
79silverstreak's Avatar
79silverstreak
Hey yall'
After setting for a while, my factory 79 power steering pump has seen better days. If replacing, I figure perfect time to upgrade. Has anyone had any experience with a good(maybe Saginaw) pump that was fairly easy swap? Also, no matter how much I "flush" the system, fluid is milky, assume that's on account of water. How would I go about removing all of that contaminated fluid out of my gear box? Rebuild?
Thanks, James
Edit: Sorry, misspelled title.
Old Feb 4, 2013 | 08:26 PM
79silverstreak
Oh, I'm not sure if it makes a difference, but it's a 400, f250.
Old Feb 4, 2013 | 11:17 PM
73 ford guy's Avatar
73 ford guy
saginaw pumps are awesome. youll need to fabricate a bracket. you could try flushing your system. type F atf might be what your pump calls for. i put axle on stands and turn wheel lock to lock with engine off and with engine on. if theres lots of bubbles let it sit for the day or overnite and do the lock to lock turning again untillall bubbles dissapear. it can be a pain sometimes.
BstangBill
Nov 18, 2018 10:38 AM
Fordbronco69
Nov 9, 2013 04:46 PM
Unimog005
Feb 26, 2007 07:53 PM
ADSf100
1978 - 1996 Big Bronco
May 13, 2005 09:46 AM
92exploder
Aug 4, 2003 06:28 PM
