wondering how hard it'll be to remove the computer to install a jet performance module on the computer??...anyone have any dealings with the jet module??
It would probably help if we knew something about your truck. I'll assume it's NOT the one in your signature, since this is for the 8th & 9th gen trucks, and a '97 is 10th.
yes its my 97 f250 5.8
i had it scanned once for check engine light, i couldn't remember where they hooked it up at. o2 sensor was the check engine light problem. got it fixed!...i've seen good things from jet performance, on a lifted 2000 f250 v10, he got about 4 mpg more and his power and shifting was better. I seen on another site you can take the e-brake loose and slide it out that way also, not sure how that works?
Just because the OP's truck is a 1997 9th gen. truck does not automatically make it OBD-II. In most cases these off-the-shelf chips do very little on this vintage truck. They firm up the shifts a little and bump the timing a few degrees which in many cases requires the use of higher octane fuel. The timing bump can be accomplished for free by bumping the base timing up from 10 BTDC to 12-14.
If the OP's truck is OBD-II my money is on the Jet chip will have the same effect, lighter wallet and no real performance or mileage gain.
my truck dont have mass air flow sensor...not sure what generation it is, but its the same as 92 - 97 old body style fords, it has the stock square air box with 2 tubes running to the throttle body, if it has a mass sensor somewhere i dont know where its located??...Jet says you can use regular octane for daily driving, but for towing and better performance 89 or higher is recommended. I've seen the chip work on a 2000 v10 and older model mustangs, better gas mileage, a little more power, and makes shifting easier, its not a rocket but you can tell a difference, they make 2 different kind, one for automatic and one for manual, i've done a lot of research and heard nothing but good reviews, so i'm going to try it...if you dont like it, just unplug it and it goes back to stock settings, so as Jet says. Havent had the chance to locate the computer yet. I'll keep everyone updated
The procedure F100 posted is pretty good, by buddy Sackman created that write-up. If you want to bump the timing then set the base from 10 to something else higher such as 12,13,14...whatever your particular engine/trans./fuel combo will handle.
"1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucks"
Sorry, my bad. For some reason I thought it was only the F350s and above that held over the extra model year.
So to answer your question, PCM comes out from the engine bay side, but you'll need to remove the inner splash shield to get it all the way out.
I was under the impression that all vehicles were required to be OBD2 compliant starting in model year 1996. Was there some sort of exception for heavy duty trucks?
If indeed it's OBD2, I'd want to take advantage of the ability of that class of PCM to take a flash tune rather than an old school J3 adapter chip. That said, I question the value of custom tune on a stock engine.
