ip timing expert
Old 02-04-2013, 10:22 AM
Nick bass's Avatar
Nick bass
Nick bass is offline
ip timing expert
i have a 1990 7.3L N/A and the fuel pump on it has been turned up and recently someone had mentioned to me that it sounded as if my timing were off on the truck. i have not the slightest clue on how to time these pumps or what the engine should sound like. does anyone know any mechanics in missouri that have this know how. i live in Northwest Missouri (Maryville) or st.Louis area depending on the time of year. any help would be appreciated.
Old 02-04-2013, 12:38 PM
1989f250IDI's Avatar
1989f250IDI
1989f250IDI is offline
I am looking for someone to time my 7.3 idi as well. I live in Adair,Ok
Old 02-04-2013, 01:50 PM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
a number of guys on here own their own timing adapter, as there are almost no shops who know what they're doing.
for the OP, you should be aware that turning up the fuel as you did, does affect the timing. and trying to dial it in without a meter is just about as accurate as trying to time a gas engine by ear - if you know what you're doing you'll get it within 5 degrees of your target, but thats a huge range of error and not good enough.
all that said, you can buy the timing adapter online. heres the first one i found on google Ferret Instruments V765-01 Injector Tester - Fuel System Tools and that looks to be a pretty good price - i think i paid more for mine.
you can also post in your local chapter (bottom of forum list) and ask if anyone near you has one they could let you use.
Old 02-04-2013, 04:28 PM
Nick bass's Avatar
Nick bass
that is why i would like to get it timed out. with that tool, how exactly does it work? you clamp onto the fuel line to #1 cylinder and it senses the pulse but as far as adjusting the timing, how do you know if it needs advancing or retarding and how much?
Old 02-04-2013, 04:42 PM
joshofalltrades
the timing adapter sends a signal to your timing light, ideally to a timing light that has an electronic advance circuit so you can really dial in on where you're at. ideal is 8* @ 2000 RPM.
for adjusting, the engine MUST be off, you loosen the 3 nuts holding the IP to the gear housing, and rotate the pump. it'll be hard to move cause the steel lines are holding it, so many pumps have a wrench flat on the front of the housing to make it easier. you MUST tighten it down before starting the engine to check timing again.
rotating the pump so its top moves toward the passenger side fender, will advance it
Old 02-04-2013, 09:11 PM
Nick bass's Avatar
Nick bass
so the ferret an d good timing light will get it done? do i need to buy an adapter for #1? also while on the subject why does my #1 injector have an extension on it with a plastic sleeve over it?
Old 02-04-2013, 11:01 PM
joshofalltrades
yes, thats all it takes. the ferret meter comes with a clamp that goes over the injector line and "feels" the pulse. it just requires the line to be clean.
as for the little extension you mentioned, i've been told that was for an obsolete style of timing unit, you can just ignore it.
Old 02-04-2013, 11:31 PM
speedwrench72's Avatar
speedwrench72
speedwrench72 is offline
Do a search and u will find some vids of the process....i watched them ...must rev engine to a certin point then shoot the light at harmonic ballencer...ect
Old 02-05-2013, 03:45 PM
Nick bass's Avatar
Nick bass
thanks for the information guys. so although that extension is for an obsolete timing method does it need to stay in place? i would think that would effect normal operation for cyclinder 1?
Old 02-05-2013, 03:49 PM
joshofalltrades
it does need to stay in place unless you replace that injection line with one that originally came without it. it has no effect on the operation of the system, so we usually just leave it there. but removing it would effectively shorten that line, causing a slight change in timing for that one cylinder, which would not be good. so either leave it alone, or find a used line that never had that adapter in it.
Old 02-05-2013, 06:26 PM
akamacgyver's Avatar
akamacgyver
akamacgyver is offline
Clueless spectator!
Nick,
In order to delete the timing adapter from your #1 cylinder fuel line, you need to find a #1 cylinder line from a van, because just removing it will change the timing of that cylinder as Josh stated. The van uses the #4 cylinder line for timing, so the #1 cylinder line is correct length without the adapter. I have one that I got from another member, that I have yet to put on. It makes timing with the feret a little easier because it gives you a better location to put the piezo (SP?) clamp on within the required 4 inches from the injector. Timing with the feret is pretty simple. Here is a video of the process, along with a video of how to adjust the timing.
Good luck,
Mac.
Old 02-05-2013, 09:12 PM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
Thanks for posting those videos, Mac! I've been thinking about getting one of those Ferrets and it helps to see one in action. Smart work with those turnbuckles too!
Old 02-05-2013, 10:44 PM
Nick bass's Avatar
Nick bass
Thumbs up
yes thank you for those videos. and i have to say that is probably the best use ive seen for a mini turnbuckle
Old 02-06-2013, 12:25 AM
The_Josh_Bear's Avatar
The_Josh_Bear
The_Josh_Bear is offline
Make sure you have a timing light with the advance setting on it! I'm sure that's what you meant by "good", but I just had a regular one and was all pumped to change my timing, but no dice as International saw fit to leave only one timing mark on the engine. I now have two timing lights.
That's it, the videos show everything that's needed.
-Joshua
myoldvan
01-06-2014 11:10 PM
79sparky
02-13-2013 02:34 PM
jayro88
01-01-2013 03:02 PM
bduemig
10-18-2012 01:03 PM
coletrain777
22
03-18-2011 08:06 PM
Quick Reply: ip timing expert
