Brake controller - where to put it?
Old Feb 3, 2013 | 06:35 PM
Archion's Avatar
Archion
Veteran: Marine Corps
I'm going to be moving my Tekonsha P3 over from my old truck, question is, where do you guys put them? I dont think I want to drill into the dash face and the cubby is too small to allow access to the lever...
Where have you all put them and pros/cons? I have to take into account that I'll be throwing my CB in later to once I get a mirror mount antenna for it.
Pics are appreciated.
Old Feb 3, 2013 | 06:48 PM
hav24wheel's Avatar
hav24wheel
Got mine screwed to the dash below the little cubby. Ill have to go snap a pic
Old Feb 3, 2013 | 07:10 PM
hav24wheel's Avatar
hav24wheel
Old Feb 3, 2013 | 07:37 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Originally Posted by hav24wheel
That's where I put mine, it needs to be close to your right hand for emergency braking.
Old Feb 3, 2013 | 07:40 PM
ScaldedDog's Avatar
ScaldedDog
Mine's been in the cubby for years. It sticks out the length of my index finger, but that makes it easy to reach.
Mark
Old Feb 3, 2013 | 08:02 PM
69oiler's Avatar
69oiler
It almost looks like there is a slight recess molded into the lower dash under the cubby, perfect for a brake controller. That's where i have mine.
Old Feb 3, 2013 | 08:30 PM
Excurvelle's Avatar
Excurvelle
Mine's in the same place.
Old Feb 3, 2013 | 08:39 PM
ufvj217's Avatar
ufvj217
Mines there too..installed by previous owner
Old Feb 3, 2013 | 09:02 PM
airjeff's Avatar
airjeff
Yeah, there is a slight recess there for a brake controller. The wiring is pretty much right behind that area.
Old Feb 4, 2013 | 09:19 PM
Turfzilla's Avatar
Turfzilla
Exact spot I have mine too.
Old Feb 4, 2013 | 11:14 PM
ocboat's Avatar
ocboat
I just used the bracket to hang it over the garbage bag cleat.
Old Feb 5, 2013 | 07:44 AM
Archion's Avatar
Archion
Thanks, I did notice the little sunken spot there and that was my first thought, I just didn't want to drill visible holes in my new truck just yet...
Mark
I'll have to look at that cubby again and see about leaving it sticking out a bit. It's not like the cubby is really all that useful for me. No issues reaching the manual control? The lever on the P3 is on the bottom...
You mean you let it hang and swing? That can't let it work very well if it's a proportional controller.
Old Feb 5, 2013 | 07:59 AM
Snowseeker's Avatar
Snowseeker
Mine is at the bottom of the dash. The PO installed it and I am very glad he didn't drill any holes in my dash! It is a far reach but after initial setting up of the brakes after hooking up a trailer I don't have to touch it again. In my last truck I had the controller in the cubby.
I don't have a good pic of it but you can see it in this pic. About the same spot as pictured above but just lower, on the bottom of the dash.
Old Feb 5, 2013 | 08:37 AM
jh818's Avatar
jh818
I have mine under the cubby hole like most of us here. I did drill holes to mount it there. I figure the holes are just a small sacrifice for easy access to the manual lever. If needed, you could always get a replacement panel if you want to sell the Ex in the future.
Old Feb 5, 2013 | 09:23 AM
ExxWhy's Avatar
ExxWhy
Ditto on the location, just seemed to "fit" there. I wasn't too concerned about holes in my dash, but I'm more of a function over form type guy.
