Sponsored by: Real Truck
Reverse lights won't come on?
Old Feb 3, 2013 | 04:58 PM
zombieplow's Avatar
zombieplow
I have a '04 F-250 SD 6.0L Automatic 4x4 I think with the torq shift trans. and I can't get the reverse lights to work. Also just in case it's related my back up sensors don't work. I don't get any sort of beeping nor does the parking sensor switch off when i put it in reverse, unless i turn it off myself. I checked the relay, fuse, and bulbs and all are good. What am I missing? Thanks guys.
Old Feb 4, 2013 | 08:27 PM
powerstroke72's Avatar
powerstroke72
Not sure but I'll bump your thread to the top so somebody might be able to suggest something.
Old Feb 4, 2013 | 08:34 PM
zombieplow's Avatar
zombieplow
Appreciate it. Went back to look at it and the wiring is all in one piece. Plan was to check the TR sensor but I guess that's internal...
Old Feb 4, 2013 | 09:22 PM
pbeering's Avatar
pbeering
For the reverse lights -
Check fuses and relays (remove, inspect, replace)
Check bulbs (remove, inspect, replace)
Check sockets to see if there is power
Check reverse switch
Run the wire harness to the point where you find the plug (under the truck) disconnect the plug, clean, inspect, apply Fluid Film or dielectric grease, reconnect
For the back up sensors -
Check connections
Check plug under bumper (driver's side)(disconnect, clean and inspect, add Fluid Film or dielectric grease)
Inspect each sensor for broken lens or gunk on lens
Set brake, have helper put truck in revrse with key on, listen to each sensor, it should buzz or hum.
Failure of any single sensor will kill them all.
Old Feb 4, 2013 | 11:41 PM
zombieplow's Avatar
zombieplow
Alrighty, I'll go over it and see what happens. I work a late shift tomorrow but I'll get back to with the results hopefully Wednesday.
Old Feb 6, 2013 | 06:32 PM
zombieplow's Avatar
zombieplow
Okay so I checked everything and this is what came up:
In park the reverse lights show around .5 ohms and in reverse it's around 1.8 ohms. Also I can't check the transmission range sensor since it's internal, or at least I don't know how that process works...
Oh and I haven't got to the reverse sensors yet.
Old Feb 6, 2013 | 11:20 PM
zombieplow's Avatar
zombieplow
I would like to apologize, apparently I replaced the old relay with a new relay that was bad. Replaced the relay again and both systems work again. Thanks for the help though pbeering!
Old Feb 7, 2013 | 06:10 AM
pbeering's Avatar
pbeering
Glad to help. Remember the troubleshooting algorithm.
beefey
Nov 25, 2017 05:06 AM
Firelizard
May 27, 2017 06:13 PM
rideracelivemx7
Apr 19, 2013 12:22 PM
Pyancey
Jan 16, 2013 09:08 PM
cabloom300
Oct 22, 2012 08:15 PM
