M5R2 bushing posts?
Old Feb 3, 2013 | 04:04 PM
OKrumple's Avatar
OKrumple
M5R2 bushing posts?
How do you remove the interior bushing posts on the M5R2 shifter throat? I need to put a bushing rebuild kit in, I do not know how to remove those interior posts.
Old Feb 3, 2013 | 04:37 PM
Ed Bamba's Avatar
Ed Bamba
Not sure if I'm following you correctly, but if you are referring to the part of the shift lever that is attached to the top plate then you just need to remove the three scews on the top cover. Make sure that the transmission is in neutral or you may have a difficult time when you go to reinstall it.
To replace the bottom bushing, you will need to remove both pivot pins that are pressed into the sides the top plate.
Old Feb 3, 2013 | 04:41 PM
F150xlt's Avatar
F150xlt
The two pivot pins are a press fit.
Put the flat face of a screwdriver or chisel against the pin.
With a small hammer tap one of the pins till it's flush with the
cover. No need to remove it.
This will allow enough clearance to remove the old lower bushing.
If any of the pins are worn you can purchase replacements.
In that case you can use some loctite on the pins.
Old Feb 3, 2013 | 11:17 PM
OKrumple's Avatar
OKrumple
Yup those are the little posts or pivot pins I'm talking about. I didn't want to break anything being cast aluminum! Thanks!
Grantmh6.4
Nov 23, 2018 09:41 AM
sdraymond
Feb 20, 2016 04:35 PM
nibog
Jun 30, 2006 01:17 PM
51dueller
Mar 28, 2003 05:41 PM
topscout
May 24, 2002 07:32 AM
