Temp Gauge
Old Feb 6, 2013 | 08:46 AM
720Deere's Avatar
720Deere
Anywhere below 30 degrees ambient temp, I can't get mine up over 170 in less than 10 miles. This engine has a huge cooling system (actually 2 of them) and it takes a long time to bring it up to temp. They don't gain much heat sitting around idling either. Like others have said, it takes somewhat of a load on the truck to get the temps up.
Old Feb 6, 2013 | 10:41 AM
doczenith1's Avatar
doczenith1
Originally Posted by Sqidget
Thanks so far for the insight. I was just looking to compare this truck to other 6.7s to determine if it was normal or defective. My 7.3 warmed up in about 1/4 the time this one takes, same routes. I am not talking cabin heat, actually attaining normal coolant temps.
Thanks again for all replys so far, Dave
If you want to do a quick, somewhat related, test you could compare your start-up idle temps against my truck. The data is in the rapid-heat spreadsheet available via the link in my signature. On one of the test with 5 degree F ambient temperatures it took about 14 minutes to get the oil temp to 100 degrees idling only. Plugged in it only took about 5 minutes.
3000gtman
Dec 19, 2016 10:08 PM
hornychief
1997 - 2003 F150
Jan 28, 2014 08:23 PM
grec-o-face
18
Feb 15, 2013 01:46 PM
usafstud
1997 - 2003 F150
Dec 19, 2010 10:17 PM
FordTE
Nov 29, 2003 03:02 PM
