Sponsored by: Real Truck
ABS Light
Old Feb 3, 2013 | 07:18 AM
Capt. Bob's Avatar
Capt. Bob
ABS Light
Hi to all. Newbe here with a question. I was driving down the interstate with cruise control set on 70 mph. in my 2006 F-250 with the 5.4L engine when all of a sudden the cruise went off and the ABS light came on. The little car that was tailgateing me amost bought me a new bumber. I reset the cruise and it works fine but the ABS light still stays on. Owners manual just says "have it serviced". What does that intail? I usually don't take my equipment to the dealer unless I am trading it in. Has anyone else have any experience with this. Thanks
Old Feb 3, 2013 | 08:47 AM
projectSHO89's Avatar
projectSHO89
Most likely, you lost an ABS sensor or a wheel tone ring.
You'll have to have the ABS codes pulled from the ABS module to pinpoint the fault area. Any decent shop scan tool should be able to do this. The really cheap scan tools won't although there are some out there for under $200 that appear to do so.
Old Feb 3, 2013 | 08:48 AM
fmtrvt's Avatar
fmtrvt
The problem most often is related to the wheel speed sensor coming off the rear axle differential. The most common issue is the build up of normal wear iron particles on the sensors surface cases it to misread or fail over time. Sometimes just pulling it out of the top of the pumpkin and wiping it off clears the issue, other times a replacement of the sensor will take care of it. Easy to do and not that expensive.
The second issue that has popped up from this circuit is over time the wiring harness to the sensor can break from fatigue from the axle's movement. Much rarer.
Old Feb 4, 2013 | 05:00 AM
Capt. Bob's Avatar
Capt. Bob
Thanks again for the replys. As soon as I can clear another project from my shop. I will see what I can find and post results.
Old Feb 4, 2013 | 05:12 PM
Capt. Bob's Avatar
Capt. Bob
truck fixed
I got under the truck today and found the sensor on top of the pumpkin and unpluged the wire connection to remove the sensor and lot of sand came out. I plugged the connection back in and cranked up and rolled the truck down the road a little and the ABS light went out. Truck fixed. Thanks again guys.
ford4ever_2003
Nov 26, 2017 08:09 PM
dogg16
Jun 25, 2010 06:33 AM
herman2001
Sep 15, 2006 03:56 PM
davenpt
1997 - 2003 F150
18
Sep 27, 2005 04:52 PM
