hood hinges
Old Feb 2, 2013 | 09:49 PM
72camperspecial's Avatar
72camperspecial
hood hinges
Getting ready to remove the hood hinges to get to the inner fenders. I was wondering if I need to score the inner fenders before removing the hinges? I plan on replacing the rh side inner fender because the battery acid created a big hole in it. Is there a problem aligning the hinges when putting the hood back on so the hood will latch? I need to find the thread on how to enter pictures ini a post. I have been a member for about three months. I did post some pictures in the gallery under 72camperspecial. Any ideas would help. This is my first restoration project.
Old Feb 2, 2013 | 10:45 PM
HIO Silver's Avatar
HIO Silver
Don't score. Drill baby drill!
First align the hood the best you can. When satisfied, use a 1/8-inch bit and drill two holes through the hinge plate and the inner fender - one towards the front of the hinge and one at the back. That's because these hinges can tilt. Then drill one hole through the upper hinge plates which attach to the hood. Then remove the hood and hinges.
When re-installing, use two bits as indexing tools to line up the hinge again and snug 'er down but not too tight... you don't want to spin the captured nut (ask me how I know). Then reinstall the hood using drill bit again to index it to the upper plate.
You're only gonna have 1/4 of the battle since you're replacing one inner fender.
Btw, the same principle described above also works for doors and door hinges.
Old Feb 3, 2013 | 05:12 AM
jowilker's Avatar
jowilker
Or you could use the carpenter method with less expensive nails rather than bits. Just gotta keep it ligned up.
John
Old Feb 3, 2013 | 09:25 AM
72camperspecial
Thanks for the tips that is what I was looking for. I looked over your garage photos, nice trucks hope some day mine will be in top shape.
Old Feb 3, 2013 | 11:07 AM
willowbilly3's Avatar
willowbilly3
That's a great idea. I have fought those hoods for hours trying to get them just right. Usually getting the back to drop down is the hardest part for me.
bulldogcountry1
15
Jan 1, 2018 05:22 PM
Mercman54
Dec 4, 2017 10:57 PM
stayxcalm
Aug 21, 2015 10:11 AM
zpmps2
Nov 25, 2007 09:48 PM
1955effie
Feb 26, 2007 07:24 AM
