Tire size?
Old Feb 2, 2013 | 10:02 AM
docweld's Avatar
docweld
Tire size?
What is the biggest tire size I can put on my 2007 F150 stock rims?
I have P275/65R18 on it now
Old Feb 2, 2013 | 10:50 AM
bigunit54's Avatar
bigunit54
this might help you.
Tire and wheel fitment guide for 04-08 - Ford F150 Forum - Community of Ford Truck Fans
Old Feb 2, 2013 | 11:01 AM
docweld's Avatar
docweld
Thanks! a leveling kit would raise the front up 2"? sorry if it is a stupid question.
Old Feb 2, 2013 | 12:17 PM
bigunit54's Avatar
bigunit54
You can get 2" or a 2.5" in kit. It is just a spacer that goes on top of the front struts.
Old Feb 2, 2013 | 12:19 PM
docweld's Avatar
docweld
nothing else is needed? shocks??
33X12.5" or 35X12.5" would really drop my MPG'S??
Old Feb 2, 2013 | 03:47 PM
bigunit54's Avatar
bigunit54
Yes you will lose 1.5 to 2 MPG. If you research the leveling kits a bit you will see how they are set up. There are a lot of them on EBAY. You can keep your existing front Coil on spring and then the spacer goes on top.
Old Feb 2, 2013 | 03:53 PM
TexasReb's Avatar
TexasReb
You can use spacers or you can use the:
Bilstein shocks and struts for cars and trucks - Shockwarehouse.com
or
2005 FORD F 150 Rancho Quicklift Suspension Lift Systems RS999910 - SummitRacing.com
Old Feb 2, 2013 | 04:36 PM
bigunit54's Avatar
bigunit54
I used the Rancho quick lift quick struts. As you can see in my sig. I like them. Gave me 2" exactly.
Old Feb 2, 2013 | 08:35 PM
curtk69's Avatar
curtk69
my 17x7.5 rims have 315/70/r17s on them but they do rub a little on uca and sway bar at full lock, not a big deal just cant get as tight of turns in parkin lots
Old Feb 3, 2013 | 09:52 AM
4getfulbj's Avatar
4getfulbj
i had 305/70/17 on stock rims and alot of people said not to but i had no problems. a little rubbin but nothin a grinder cant take care of.
Old Feb 4, 2013 | 09:30 PM
The Oldtimer's Avatar
The Oldtimer
I have 295-70-18 Nittos on my FX4 on the stock rims with a 2" lift up front. They rub a little when turning sharply...at 34 1/2 " tall they make the truck look like it should...but they are kind of noisy.
Bwalker86
2004 - 2008 F150
Feb 25, 2017 09:30 AM
stlblue38
2004 - 2008 F150
Jan 29, 2009 06:00 PM
JWHendrix89
2004 - 2008 F150
Feb 10, 2008 11:57 PM
mattpowerstroker
15
Feb 3, 2008 09:24 PM
stevegiles
2004 - 2008 F150
Jun 17, 2007 01:57 PM
