bendix box
Old Feb 1, 2013 | 11:19 PM
lefty rodan's Avatar
lefty rodan
bendix box
I have a manual steering 65 with a 289 and a c-4 with floorshift. I have a chance to buy an automatic column with a supposedly good non-leaking Bendix power steering box from a 68.
1.) Is this a direct bolt in to my 65? I know Redheads can rebuild it if need be and I won't have to hunt down a Ford box and cut the column.
2.) If the Bendix is bad does it have any value as a core?
3.) Will I be able to convert the c-4 floorshift(from a 68 Montego) to a column shift using the 68 automatic column?
Thanks in advance for your help as always. Lefty Rodan
Old Feb 2, 2013 | 04:59 AM
jowilker's Avatar
jowilker
Lefty, The column will work in your truck. Don't know about the C4, I know this about a car C6 the shift arm hangs down / at about 45 degrees while the truck arm is horizontal -, that can be problematic.
If I was thinking about adding power steering, (I was several years back) I would find a good 73-79 half ton with a 302 auto and use it as a donor for both power steering and power disc brakes. All is a direct bolt up.
John
SMH1970
15
Feb 5, 2018 05:15 AM
dusterbd13
May 18, 2015 01:43 PM
jhooch
19
Jan 23, 2009 03:11 PM
EdVF1000R
Sep 1, 2003 10:58 PM
williamwilliam
15
Jul 21, 2003 09:18 PM
