Plans change..........
Old Feb 1, 2013 | 02:06 PM
Dobies4life's Avatar
Dobies4life
Ok so my truck build has changed. My fat fender is going to use a Ranger frame. So it seems this 6 quart front sump pan will be useless. The local rod shop has a frame swap done with rear sump 302. The guy was more than willing to show me what he did to get the rear sump 302 to fit. And when we were done going over everything, he said " good luck" with the cleveland install. the 302 was tight and the C will be even tighter.
Now these rear sump pans for fox bodies look like they should work. however the price tag does not set well with me. Im very curious if anyone has just fabricated their own rear sump pan? I still have my factory pan. Its damaged, but the mounting face area could be used as a base for fabrication. Or stock and 6 qt pan merged together. Using the canton pan layout they publish to show clerances.
Old Feb 1, 2013 | 03:30 PM
mark a.'s Avatar
mark a.
Can you use the 4x4 351M-400 rear sump pan ? If you are using an auto trans, I'd stay away from any aftermarket pan. Everyone I have ever seen butts right up to the bellhousing making it impossible to get at the t.c. studs.
Old Feb 1, 2013 | 05:20 PM
Dobies4life
No on the auto trans. I will be using a 5 speed. The 351m, 400 pan does fit the C, however an OE is about impossible to find. I havent found any OE replacements. But i did find the aftermarket racing ones. And like i said the pricetag on them is kinda crazy.
Old Feb 3, 2013 | 06:16 AM
udsuth78's Avatar
udsuth78
Ford Rear Sump Oil Pan 351M 400 351C 4x4 F100 F150 F250 F350 Mud Rock Crawler | eBay
Old Feb 3, 2013 | 06:30 AM
mustang81's Avatar
mustang81
351C Fox Body Rear Sump Pan [CAN15-720] - $328.29 : Performance Racing Group, The Professionals Choice - Now available to the Public!
i saw a guy modify a 351c pan once with pictures but can't find it now.
I found some dimensions for a rear sump pump:http://www.hrpworld.com/index.cfm?fo...action=product
Ratty51F1
Nov 13, 2017 06:30 PM
Dobies4life
Ford Truck Parts for Sale
Feb 9, 2013 09:03 AM
Tat2ed64f100
Nov 6, 2008 08:29 PM
sancochojoe
May 3, 2005 02:52 PM
winfordr
Sep 24, 2002 08:19 AM
