Sponsored by: Real Truck
aux. rear lighting
Old May 29, 2003 | 12:06 PM
Plow Jockey's Avatar
Plow Jockey
aux. rear lighting
I have mounted a pair of 55 watt halogen lamps to the trailer hitch for better visability when backing while plowing.
My question here is.........I want to have them come on when I put the truck into reverse only. Can I hook them up to the trailer harness? I have the tow package and the large round receptical and I found that there is a reverse lamp pin in there.
Can I hook them up directly or should I use a relay?
Old May 29, 2003 | 01:25 PM
Fredvon4's Avatar
Fredvon4
aux. rear lighting
I would use a relay and run a 10 gage hot from the battery all the way back to the aux lights. 110 watts is a lot of amps on the 10 or 12 gage wires that are already back there.
You should be able to locate the hot for the factory reverse lights and trigger the relay with it. But I would opt for a seperat switch also so you can use them any time.
Old May 29, 2003 | 01:28 PM
CBSuperduty's Avatar
CBSuperduty
aux. rear lighting
Check out Stan's page. He has a bunch of info. The link is how he did his backup lights. Hope this helps.
Old May 29, 2003 | 04:36 PM
Karic's Avatar
Karic
aux. rear lighting
PJ;
CB's right, Stan got a great website, and he's also really good at responding to emails.
Rick
Chris, check you own email.
Old May 29, 2003 | 05:17 PM
hthighway's Avatar
hthighway
aux. rear lighting
Ya, Stan's page is great. That is where I got the info to install mine.
I made my own diagram to help myself understand it better.
Old May 30, 2003 | 12:53 AM
Plow Jockey
aux. rear lighting
Thanks for the replies guys.
I think I'm going to take Fredvon4's advice and add an in-cab switch. Might come in handy for those tailgaters and the "OOPS I forgot to turn off my brights" idiots.
Old May 30, 2003 | 03:46 AM
SouthernDually's Avatar
SouthernDually
Thumbs up aux. rear lighting
When I put my white knight system I did notice that I do have an aux switch.. Now I know where to put the switch.. Thanks guys.
