Brake Proportioning valve
Old Jan 30, 2013 | 03:26 PM
Rovernut's Avatar
Rovernut
I'm pretty sure the one on my truck is bad. It's the type with the lever that moves when you add weight to the bed, as seen on the left in this photo:
I'm assuming they are fairly expensive, but I haven't found one online, don't know what the part number is to search for.
Anyway, I'm thinking of replacing it with one of these for about $40 from Wildwood:
http://www.wilwood.com/MasterCylinde...emno=260-10922
Anyone have the PN for the stock Ford valve, so I can see how much they are?
Old Jan 30, 2013 | 05:52 PM
ctubutis's Avatar
ctubutis
Looks to be a variation of a 2B547 (BRAKE LOAD SENSING PROPORTIONING VALVE) Sec 23 Pg 6
I need to know the year and model (looks to be 1985 F250 based on your Garage entry under your username in the top-left corner (I don't display sigs)) as well as:
- 2WD or 4WD
- GVWR
- Engine size
Old Jan 30, 2013 | 06:15 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Why do you think it's bad? Mine still works quite well.
Old Jan 30, 2013 | 08:03 PM
Rovernut's Avatar
Rovernut
Sorry.
1985 F-250XL 4WD, 460, Ford 10.25" rear, Dana 44 TTB, 8,600 GVWR
The rear brakes lock up too easily.
I'm about to do a complete brake refurb from the MC to the rear. Once I do that I'll see if there's any change, but I want to have a solution in my back pocket, so to speak, in case there's no change in it's operation.
Old Jan 30, 2013 | 08:39 PM
ctubutis's Avatar
ctubutis
Boy, this post is gonna be filled with bad news....
The Parts Catalog says it could be one of two:
E5TZ-2B547-F - Fits 1985/ F250 4WD with 6.9L or 7.5L engine with rear springs E3TZ-5560-T
E5TZ-2B547-C - Fits 1985/ F250 4WD with 6.9L or 7.5L engine with rear springs E3TZ-5560-M
Notice, those spring numbers are factory replacement spring numbers, not the numbers on the springs your truck came with.
I have absolutely no idea which rear springs you would need and likely neither do you.
To add to that, the parts catalog doesn't give complete spring information, so even if I had a code from your Certification Label I couldn't do anything with it.
More bad news.... for the -F variant, no dealers or NOS vendors have any.
I show two Ford dealers who each claim to have one of the -C variant (whether they could find it or not is anybody's guess):
Friesen Ford in Aurora, NE
XIT Ford Chrysler in Dalhart, TX
And the senator, while insisting he was not intoxicated, could not explain his nudity.
Old Jan 30, 2013 | 10:01 PM
Rovernut's Avatar
Rovernut
Well, it looks like the manually adjustable valve will be the route I take if I need one. I can't imagine 1 of only 2 available NOS valves being anywhere close to only $45.
Thanks much for the info.
Old Jan 31, 2013 | 09:23 AM
85lebaront2
The issue I see that you might run into would be having to adjust it for each different load condition. My truck will lock the rear wheels during a panic stop unloaded, always has.
Old Jan 31, 2013 | 10:36 AM
Rovernut's Avatar
Rovernut
Yeah, I can see that as a possible issue, but I'm generally either very lightly loaded, or very heavily loaded.
Locking during a panic stop is one thing, but locking when the road is wet at a very light stop (or dry road with just a slightly more aggressive stop) isn't good.
Old Jan 29, 2021 | 08:08 AM
Rovernut's Avatar
Rovernut
Looking for something else I came across this thread I started and never provided a result.
I took load proportioning valve apart, cleaned it up, painted it and lubed the moving parts with Never-Seez and it worked fine.
Goethfather
Aerostar
Mar 19, 2018 09:48 PM
Aerotech
Large Truck
Oct 26, 2017 09:01 PM
raven3
Nov 1, 2015 11:10 AM
tfmech
Feb 3, 2011 05:07 PM
MustangGT221
Feb 1, 2006 06:08 PM
