Rough Country 2" Leveling Kit
Old Jan 30, 2013 | 08:21 PM
Shack Rat's Avatar
Shack Rat
Originally Posted by SavageNFS
I'm not calling you a liar, but those just don't look like 35's to me at all. The darkness of the wheel wells isn't helping the illusion though. Here is mine with 35's and the snowplow prep springs.
Savage,
Could you please tell me what is the offset of those wheels
Last edited by Shack Rat; Jan 30, 2013 at 09:05 PM. Reason: Found answer to first question
Old Jan 30, 2013 | 09:10 PM
SavageNFS's Avatar
SavageNFS
Shack Rat...looks like you saw the answer to the first question. The wheels are 20 x 9 and have a -12 offset. Rear blocks are 3.5".
Old Jan 30, 2013 | 10:16 PM
Shack Rat's Avatar
Shack Rat
Im sorry, but I am confused. Somewhere in the hours and hours of researching tire size and wheel offset in the last few weeks, somewhere in this forum I saw a 20x10 wheel with -18 offset, and the tires (35x12.50x20) stuck out 2" from the fender. A 20x9 wheel with -12 offset should stick out like a 1/4" less than the 20x10 -18. From the picture of your truck, the tires look like they are right even with the fender. Can you please shed some light on this. Thank you
Old Jan 30, 2013 | 10:23 PM
SavageNFS's Avatar
SavageNFS
The second picture prolly shows it best, but clearly, mine stick out past the fenders about a 1.5". You're not nuts, the picture is deceiving.
Old Jan 31, 2013 | 10:03 AM
Shack Rat's Avatar
Shack Rat
Thank you for your response and the pictures. I really appreciate it.
Old Jan 31, 2013 | 10:08 AM
SavageNFS's Avatar
SavageNFS
No problem...please post some of your own when you make your decisions. Good luck...
Old Jan 31, 2013 | 11:36 AM
Joe_planet's Avatar
Joe_planet
I did a 2" leveling kit from ebay, cost me $20. I would definitely recommend a leveling kit! The one thing you should know is that the lift will cause your axle to shift over at least 1/2". I had to get an adjustable track bar in order to recenter it. That was the expensive bit at over $200. in the end it looks badas! I put 35x1250x20 on it and did some bushwacker fender flares.. i dont have a pic right now... sorry
Old Mar 8, 2013 | 04:49 PM
Boston Mike's Avatar
Boston Mike
I opted to go the cheap route and just swap out my stock tires from OEM rims to after market rims. I want to do some more homework on what I really want in a lift.
Downside is now the side steps and grille STICK OUT majorly. LOL.
Old Mar 8, 2013 | 07:19 PM
13Platinum's Avatar
13Platinum
That is a great looking truck! Mine has the snowplow prep also. Does that help the 35's clear with no rubbing?
kickstand03263
Jan 4, 2022 12:47 PM
Stroking2017
Feb 20, 2017 10:59 AM
blue924.9
Apr 12, 2013 02:57 PM
FordGuy85
Oct 11, 2011 08:16 AM
1979FordF-250
2004 - 2008 F150
63
Aug 18, 2007 09:29 AM
