6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
A Whistling Noise
Old 05-24-2013, 05:46 PM
bubbasz1's Avatar
bubbasz1
bubbasz1 is offline
After listening to the video could it maybe be a heat shield doing it??
My old 2001 F350 V10 used to do something like that at a certain RPM only when cold and it was a heat shield.
Old 05-24-2013, 08:20 PM
FORDSDOWNER's Avatar
FORDSDOWNER
FORDSDOWNER is offline
From the youtube comments for the video posted earlier...."I haven't fixed it yet. But, I have found where the noise is coming from, it is the Pillar on the driver side that the noise is coming from. When I pull on the handle when the noise appears, I can change the sound. I believe it is a small leak in the windshield that isn't sealed and it's allowing air to come through. Let me know if this helps or if you need me to explain better."
Old 05-26-2013, 10:29 AM
Jay Sehi's Avatar
Jay Sehi
Jay Sehi is offline
My 2010, F-250, extended cab is doing the same thing, on the way to Nashville Saturday, (just bought the truck) I found lose trim on the lower driver's side exterior, I used a piece of DUCT Tape to hold it down and returned from Nashville the same day and never heard it again... I was searching the web for a repair when I found this... I am thinking that if I take it to a windshield place they can fix it quickly...
I will be heading back to Afghanistan on 5 JUN, I will try and get it taken care of and get the results on here before I leave...
Old 05-26-2013, 12:22 PM
FORDSDOWNER
Can't appreciate ya enough. For 1) trying to following up to the possible solution of this problem were most people don't (most annoying) and 2) heading to a place such as Afghanistan...for obvious reasons.
Best of luck.
Old 07-25-2013, 11:29 AM
tcrowls's Avatar
tcrowls
tcrowls is offline
my 2011 F250 is doing too - 20K miles
still investigating, intermittent, today did it exactly as i went under a bridge started and stopped in entry and exit so must be a wind leak somewhere?
dealer blamed aftermarket wiper blades but changed them still does it?
Old 07-25-2013, 02:55 PM
FORDSDOWNER
I can grab my o-sh!! handle and change the pitch of the noise on my drivers side a-pillar when the noise is happening. Gotta be a seal.
Old 07-26-2013, 08:37 AM
FordService's Avatar
FordService
FordService is offline
Official Ford Rep
Hi tcrowls and FORDSDOWNER,
Send a PM my way with your information (VIN, dealer, mileage, daytime phone number, and full name) so I can look into this for you. I'll be happy to check out options to assist!
Crystal
girlsluvtrucks
2015 - 2020 F150
02-18-2018 04:47 PM
ecotree
07-01-2008 06:44 AM
jrangel
1997-2006 Expedition & Navigator
09-07-2003 09:09 PM
johntucker05
06-09-2003 11:47 PM
devilinuniform
05-21-2002 01:23 PM
Quick Reply: A Whistling Noise
