decoding Door tag/axle question
Old Jan 29, 2013 | 05:18 PM
abbysford's Avatar
abbysford
hello all, i have a 75 hb that i am trying to find out what front axle i have... the code on the door reads B4P, in the book i have this says dana 60. Am i decoding this correctly? i cant see it on the axle itself, but everything else on the truck is original, so i am assuming that what the tag reads is correct.
Old Jan 29, 2013 | 06:19 PM
montana_highboy's Avatar
montana_highboy
B4 = Dana 60 Rear Axle / 4.10:1 / Limited Slip / 5,300 lbs. rear axle capacity.
P = Dana 44-6CF Front Axle / 4.55:1* / 3,500 lbs. capacity / Power Steering.
*The 4.55:1 ratio is an error in the parts book, the correct ratio is 4.09:1
Old Jan 29, 2013 | 08:32 PM
abbysford's Avatar
abbysford
thx, i appreciate it, although I checked out fordification & it reads dana 60 also, so i am a little bit confused.
Old Jan 29, 2013 | 10:43 PM
montana_highboy
I am a little bit confused at your confusion, please elaborate on your confusion...
Old Jan 30, 2013 | 04:47 PM
abbysford's Avatar
abbysford
Confusion is this: The P code in my 75 book says Dana 60 front w/ power steering. The P code on fordification website says Dana 60 front w/ power steering. You replied that the P code = Dana 44. Therefore I am confused..I am not sure which is correct..Is there anything visual I could check (other than the stamp I cant see) for verification?? thx.
Old Jan 30, 2013 | 04:52 PM
hickory1991's Avatar
hickory1991
Do you have a metal tag under one of the cover bolts? If you do maybe we can decode it from that. Also if cover bolts are 1/2 inch= D44 9/16=D60.
Old Jan 30, 2013 | 04:54 PM
abbysford's Avatar
abbysford
hey thx hickory, i will check that out next time i get the chance. i'll let you know what i find.
Old Jan 30, 2013 | 05:27 PM
montana_highboy
Your truck is a '75 therefore the "P" code denotes a D44 (heavy duty)
Were your truck a '76 the "P" code would denote a D60 (low pinion)
If your '75 came equipped with a D60 you would have an "R" code.
Old Jan 30, 2013 | 06:55 PM
70 Bronco TX's Avatar
70 Bronco TX
I have a door tag that clearly says I have a D60 w/power steering on my 75 250 but it's clearly a HD D44. Can't explain it either and don't think someone swapped in a D44 and connected all the steering components, but it's the reality for me. I know it's a HD D44 because of the stamp and the bolt size on the diff.
There's an old thread on this site with key words "Dan" and D60" and "axle" and "HD44" to check out. Pics and other goodies.
EDIT: Found it here https://www.ford-trucks.com/forums/9...44-or-d60.html
Old Jan 30, 2013 | 07:42 PM
abbysford's Avatar
abbysford
thx to all of you. i will check the bolt sizes & see what i have. I was assuming it was a 44 until i checked the door code. Whatver it is, i appreciate the help.
Old Jan 30, 2013 | 07:53 PM
montana_highboy
Both you guys have '75's (as do i) we all three have the B4P axle code
B4 = limited slip D60 rear
P = Dana 44HD front
If you're getting your info from the 1975 Truck Shop Manual (or Fordification) the D60 "P" code is a typo, the correct codes for '75 are as follows...
"Q" 3,000lb D44
"P" 3,500lb D44HD
"R" 3,800lb D60
Old Jan 30, 2013 | 11:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Info on Fordification is from the 1973/79 Ford Light Truck Parts Catalog, available on a CD from hipoparts.com
This same CD catalog is being used by Fordification, montana highboy, mikeo0o0o0, jermafenser.
This CD catalog was scanned from an early edition, has errors and omissions.
The alternative would be an original loose leaf paper catalog (if you can find one), or microfiche, which is what I'm using.
Old Jan 30, 2013 | 11:28 PM
Ford6.02005's Avatar
Ford6.02005
If your truck is a regular cab and the front axle is original it is a Dana 44...Ford didn't put a Dana 60 front in a regular cab truck until 1978. Look at front side of passenger side axle tube near differential housing for a 6 digit number starting with a 6- this will identify the axle in great detail.
Old Jan 30, 2013 | 11:46 PM
NumberDummy
The Dana 60 ID tag number is stamped on an approx 2" x 1/2" metal plate that is bolted (2 bolts) to the housing, adjacent to the inspection cover on both front driving and rear axles.
So, it will be on the right (passenger) side, adjacent to the inspection cover on front driving axles. On the left (drivers) side adjacent to the inspection cover on rear axles.
The number begins with a 6 followed by either 6 or 7 numbers.
The Ford ID tag is located under one of the bolts that retains the inspection cover to the housing. Many of these tags are missing today.
Old Jan 31, 2013 | 08:30 AM
abbysford's Avatar
abbysford
Ok, I got a chance to check it out. The bolts on cover are 1/2". The metal is tag reads 4 09 D3TA-HA 603396-1.
