towing
Old Jan 29, 2013 | 12:33 PM
92blue on uhhhh blue's Avatar
towing
anyone know why the e40d is rated to tow more than the manual transmissions. the e40d can tow 3x more than a truck that is the same but has the manual
Old Jan 29, 2013 | 12:53 PM
statedclerk's Avatar
statedclerk
The factory rates autos higher because they don't want inexperienced clutch users complaining about clutch life. It's all in experience.
Old Jan 29, 2013 | 12:58 PM
i can see that but really 2k vs 7k thats quite a difference. also why are the lower gears rated less for towing with the 4.9 i have 3.08s and when if downshifts it puts it right at the factory peak torque rpm where as 4.10 or possibly even 3.55 would rev passed the peak torque rpm. or are the factory numbers inacurrate
Old Jan 29, 2013 | 01:17 PM
andym's Avatar
andym
There's also another reason. Ford used the M5OD for many years and it's simply not suited for towing or hauling that much weight. It won't hold up nearly as well as a ZF or an E4OD will.
Physics.
Work = force * distance
It's the same reason that a vehicle will accelerate much faster in lower gears than in higher ones. A lower (numerically higher) gear ratio gives you more usable torque at the wheels.
More torque = more towing capacity.
Old Jan 29, 2013 | 01:19 PM
wouldnt it be counter productive if the motor has already made peak power
Old Jan 29, 2013 | 01:48 PM
stewart89's Avatar
stewart89
Doesn't matter as much because your gear ratio is relative to the torque output at the wheels. Once you get into the higher gears, your ratio transmit less torque.
Old Jan 29, 2013 | 03:29 PM
Conanski's Avatar
Conanski
As the gear ratio gets higher(numerically lower) the pinion gear gets progressively smaller compared to the ring gear and smaller pieces can't handle as much TQ as bigger pieces so the load rating of those parts will be lower.
Regardless of the engine it's attached to and the operating rpm at any given speed, lower axle gear ratios(3.55s or 4.10s) put more torque to the ground(higher mechanical advantage) so towing performance and unloaded acceleration improves.
Old Jan 29, 2013 | 04:14 PM
DIYiT's Avatar
DIYiT
This. Autos also multiply torque because of the torque converter which helps improve towing for the otherwise same truck.
Old Jan 29, 2013 | 06:45 PM
andym's Avatar
andym
I thought it was backwards? Lower gears are not as strong as higher gears is how I thought it worked. But I may be misremembering.
No. Gears multiply torque. If the motor makes 200 lb-ft of torque, a set of 3.08 gears will deliver 616 lb-ft to the wheels, assuming a 1:1 transmission ratio and no parasitic driveline losses. A set of 4.10 gears will deliver 820 lb-ft of torque.
Old Jan 29, 2013 | 07:45 PM
Conanski's Avatar
Conanski
No I think you're right and got it basakwords...
James Wagoner
All Things Towing
Apr 10, 2018 11:22 AM
gopherslayer
All Things Towing
Sep 7, 2017 10:42 AM
JlaneAK
Mar 19, 2017 01:04 PM
dtpatt2
Jun 29, 2003 12:43 PM
Shannonm1
All Things Towing
Jun 3, 2003 07:12 PM
