Old Jun 25, 2003 | 05:05 PM
dtpatt2's Avatar
dtpatt2
Question 4.10
Hi folks, Got a ?, I currently have a 1993 F150, it has 3.55 gears now, but I'm looking into getting 4.10 installed. I'm doing this because my towing capacity will increase per my vehicle manual. Where do I start? Thanks...
Old Jun 25, 2003 | 11:00 PM
dtpatt2's Avatar
dtpatt2
4.10
Lil Help, Anyone???
Old Jun 26, 2003 | 11:12 AM
BigFootnHawse's Avatar
BigFootnHawse
4.10
I am not exactly sure what you are asking. But, you need to get the gears (front and rear if you have a 4x4) and install kits. Then find a good gear shop to install them unless you are experienced in doing this. After that, tow away...but don't venture too far off the tow rating.
Hope this helps.
--LR.
Old Jun 27, 2003 | 10:59 PM
ExcellentRed's Avatar
ExcellentRed
4.10
I changed my diff from a 3.55 to a 4.10 (or is it 4.11?) and it has more hauling capacity now because of the added torque at the wheels. You'll notice the RPMs will be higher. Generally in O/D 2000rmp translates into 57 mph and without O/D 2000rmp is about 40 mph. The added torque is also nice in rain and such because it helps to add a little traction and a more serious engine brake.
Old Jun 28, 2003 | 10:15 PM
MustangGT221's Avatar
MustangGT221
It doesn't really help the towing capacity, as there are gobs of items that determine that number. It's expensive, 300-350 in parts for the rear, and a good 300ish for the front too. I just did this, I got 4.10 for the rear and 4.09 for the front. I just bought all the parts, but havn't installed them yet. Costs a good amount for installation too.
Old Jun 29, 2003 | 01:11 AM
andym's Avatar
andym
4.10
To directly answer your question, take the truck to a reputable shop and tell them what you want. Pay them your money, and rest assured that the job was done right.
If you have to ask how to do it, you're in over your head. It is NOT a simple job.
Old Jun 29, 2003 | 10:15 AM
StrangeRanger's Avatar
StrangeRanger
4.10
It increases towing capacity because available tractive force goes up by the percentage of change in the gear ratios. In the case of a 3.55 to 4.10 it's just over a 15% gain. That doesn't mean the tow rating goes up by the like amount but it does increase. look at the tow ratings chart in your owners manual
Old Jun 29, 2003 | 12:43 PM
MustangGT221
True, but basically my point was that there are too many items that contribute to the tow capacity.
