TPS Fault
Old Jan 29, 2013 | 12:32 PM
pholahan's Avatar
pholahan
TPS Fault
Other than taking it to the dealer, is there anyway to isolate which tire is throwing the fault? All my pressures are good and the tires are 1 year old. Nothing else has happened that would trigger a fault. 2005 Expedition EB.
Thanks
Old Jan 29, 2013 | 01:38 PM
alloro's Avatar
alloro
You could try a tire shop. They should have a scanner for checking that since they can change TPS valves. I suspect they'll be much less expensive than the dealer.
Old Feb 7, 2013 | 10:56 AM
pholahan's Avatar
pholahan
Took it to the tire shop and all 4 sensors are good. They reset the light and seems to be staying off, however he said there could be a problem in the TPM module.
GIANTOAK555
Jul 8, 2017 10:29 AM
dlgfords
Jan 20, 2011 06:18 PM
JimRietz
Aug 16, 2005 05:51 AM
dumontkid
Feb 18, 2003 08:54 AM
