Windshield wiper
Old Jan 28, 2013 | 06:43 PM
lemasters f100's Avatar
lemasters f100
Windshield wiper
The windshield wiper on my passenger side of my 1978 f250 has never worked from the time I bought it. What could be the cause of this? I dont think its The wiper motor cause the driver side works perfectly at both speeds.
Old Jan 28, 2013 | 06:51 PM
duallyhauler's Avatar
duallyhauler
Wekk either the linkage is broken, disconnected, or the **** the arm is attached to is stripped. Time to start looking.
Old Jan 28, 2013 | 10:47 PM
lemasters f100
Alright I will check that tomorrow afternoon and get back to you. Thanks
Old Jan 29, 2013 | 09:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Same parts: 1973/79 F100/350 & 1978/79 Bronco.
D9TZ-17566-A .. Right Arm & Pivot and D9TZ-17567-A .. Left Wiper Arm & Pivot connect to the stud of the wiper motor output arm (C7TZ-17A436-A) with a clip (C5ZZ-17531-B).
The left arm connects first, then the right arm. If the clip was missing or had broken, neither side would work. I suspect the pivot of the right wiper arm has stripped.
Old Jan 29, 2013 | 06:50 PM
lemasters f100
i looked at it today and saw that the part that the bar under the dash is broken off. how much is it and is it easy?
Old Jan 30, 2013 | 07:46 PM
lemasters f100
I fixed it with zip ties. And tested it out and it works
1918ALF
Jan 1, 2016 02:34 AM
Schuyles
26
Jan 6, 2015 08:59 AM
pdd
Mar 2, 2008 11:12 PM
TMG2
Mar 1, 2004 10:01 AM
