Starting Project Tonka
Currently I have stripped and sold the dodge donor truck and reinvested the money in the drivetrain axles. The body has more rust and issues than anticipated so currently i'm seeking a new body with any other parts that are needed from fords. Tomarrow I'll drag out the chassis and finish removing all the hardware and reposition in shop.
Plans to incorporate:
I removed the 35 gal fuel tank from the dodge and plan to set it in place of the front tank on the truck, then plumb it directly to the motor. Then I'd like to install an electric pump in the side box of my utility box, Will be nice to have a diesel spray hose and 10 gallon tank.
Get an A/C compressor on the motor and make an onboard air system with a 10 gal tank undernearth the truck.
Run a PTO off the Trasfer Case to a 10ton tulsa winch on a bumper. Possibly get an automatic steering shaft and hook the linkage from the selector to pto selector, that'd be cool.
Use the Front/Rear fuel switch for outside lights/work lights
Build a Lumber rack with a sliding trolley capable of lifting and rolling 800lbs 5' out the back of the truck(for loading and unloading transmissions and welders. Ganna take a bit of engineering to figure this one out.
Just curious has anyone ever tried making side pipes with steps built in?
Keep you updated every so often.
Last edited by Diesel Reaper; Feb 9, 2013 at 07:41 PM. Reason: spelling and grammar
( * = paid
Budget
*$2500 - 1990 dodge 2500 diesel 4x4 manual donor truck
*$1300 - 1991 Ford F350 diesel auto 4x4 donor truck
*$500 - 1986 Ford F350 Cab and Chassis diesel manual 4x4
$240 - Boost,Pyrometer,Fuel Pressure Guages and sensors
$225 - 5.9l Cummins full gasket set
$40 - H1C turbo seal kit
$25 - vacuum pump/power steering seal set
$25 - VE injection pump seal kit
$40 - metal for fabricating motor mounts
$30 - driveshaft carrier bearing
$40 - pilot bearing
$55 - throw out bearing
$230 - for getrag 360 rebuild kit w/ synchros
$200 - for Ford Married NP205
$125 - Ford np205 rebuild kit
$50 - metal for Transmission/Transfercase adapter plate
$60 - 3 gal of 15w40 DELO, 1 gal Lucas Motor Additive
$15 - Engine oil filter
$15 - Fuel filter
$40 - Transmission fluid
$40 - Transfer Case Fluid
$50 - Chassis paint - Valspar red primer and yellow implement paint
$50 - Miscellanious clips/pins/hardware
Total $5895
Labor
16hrs - 1986 f350 Tear down to bear frame and cab
9hrs - 1990 dodge w250 Tear down to frame and cab(Still conected)
waiting to move it to my shop on thursday - 1991 ford f350 Tear down to frame and cab
9hrs - 5.9L cummins disassemble to bare block w/ crank and mains
4hrs - Getrag 5 speed disassemble to bare case
2hrs - remove input shaft dodge np205 case
Parts Sold
+$1000 - 1990 w250 rolling chassis w/ parts of cab and axles(no tires)
+$550 - 6.9l diesel w/ banks turbo t19 tranny bw1345
Questions
What is the typical pressure for 5.9l cummins. The guage people said 30psi for cummins?
I'd like to get 350hp with this motor. Bone stock right know. I'm think of turning up the power screw, grinding the fuel pin with a curved semi aggressiveness, adjusting the smoke adjuster, installing a 3200rpm governor spring, Clocking the cam gear 1 tooth forward, Drilling holes into the air filter housing, and straight piping the exhaust. At this point what would you think the motor would eb producing hp/tor. So I'm woundering if i put an hx35 turbo with intercooler kit, banks dual ram intake, and 4" exhaust would this be enough?
Thanks for the input, Tony
