Good ole' abs flashing light problem
Old Jan 27, 2013 | 07:12 PM
smarker15's Avatar
smarker15
1997 f250 auto sd 460.....
So I have replaced the brake pressure switch, the brake interlock ,and the #13 fuse. I had to use one end of the wire harness that came with the brake pressure switch to replace the old one....it was melted, and looked bad. So That plug is spliced on there.
The fuse still blows. every time I plug the brake pressure switch in the fuse blows. Even with the VSS unhooked it still blows....What is the Problem?????? thanks for the help
Forgot to add that the wife told me that the cruise hadnt been working before this....This is her truck...could be half the problem
Old Feb 5, 2013 | 09:15 PM
Customcab's Avatar
Customcab
Just jump on here to see about me brakes on my daugthers 93; and saw your post; to me either you got a expose wire that causes your fuse to blow or the switch has some type of related amp problem with the fuse capacity. I'm leaning more towards short some were.
hope this helps trouble shoot your issue.
Old Feb 5, 2013 | 09:21 PM
m300diesel's Avatar
m300diesel
Owe it definitely sounds like a short. Instead of replacing parts I would start using a voltmeter to test any potential problematic wires.
Diablo540
1978 - 1996 Big Bronco
Jul 27, 2014 11:02 PM
dubbz
1983 - 2012 Ranger & B-Series
Mar 15, 2011 03:28 PM
87wreckerman
Nov 15, 2008 02:02 PM
noobs
Electrical Systems/Wiring
Apr 17, 2006 09:30 AM
DarrylT
Jul 30, 2003 06:28 PM
