Anyone running this kit on their X 7.3 diesel? What kind of settings are you running and what kinds of temps and results are you getting? What is giving you your best results?
Since this is specifically directed at the 7.3L PSD owners, I'm gonna move it on down to the 7.3L forum since your chances of getting a reply will increase exponentially in that forum.
I got mine for $750 with free shipping... You get electronic boost and pyro gauges wit all install hardware... I needed to buy these anyway and the combo I wanted with the gauge pillar was gonna cost me close to $500 anyway... Way I see it the kit cost me about $250 and I get a warranty, a cool three stage digital controller and lifetime tech support from an American company with all American made parts!!! MONEY WELL SPENT!
Btw I called snow and got their recommended settings and how to determine what the optimum settings are for each application are.. I left them in my truck... Ill get them and post later or tomorrow... Kirkharrod... What did your setup end up costing you? What percent of your parts were made in USA (I bet low %)? I'm just saying!
Im using a washer pump and an old fuel injector, So I have about $50 into mine, and everything but the tank and injector were made in the USA. I'm just saying!
I see a slight power increase under load with mine running. I don't track mileage so I don't know or care what happens there. I run WMO so I run the WI to keep the motor clean and prevent smoking, and it works awesome for that. After about 100 miles of running water the truck runs better than it ever has even when not injecting water, So a clean combustion chamber makes a big difference.
Snow performance recommends the following to get optimal results with your kit.
Figure out your PSI while cruising at your normal cruising speed on flat land, set the MPG injection start point @ 2 psi above your cruising PSI
Next figure out your PSI at 1/2 throttle Acceleration (he said this would be when maybe your getting on an on ramp onto the highway for example), set your MPG 100% injection or max at your determined 1/2 throttle PSI
Next figure out your PSI at full throttle, and set your PWR mode to begin at 75% of your figured Max boost
I plan to figure out my average PSI for these three over the next week and post my settings on here, anyone else who figures out their settings im curious what you get, of course this is going to be driver habit and vehicle dependent but it would be nice to know what someone else is doing.
I'm also beta testing the new wicked wheel 2 for diesel site
That is great also. Can you provide some info on your truck? Mileage, other mods, what your use is? Your altitude?
My choice on kits will be somewhere in between the ones mentioned. I don't need gauges, like the idea of some programming, would like a larger bottle (gallons) because I will use for towing long distances. I also just don't want to spend as much as some. Too many other things to get.
2003 Ford Excursion 7.3 Eddie Bauer; 305,000 miles; stage 1 Swamps injectors; Banks Ram Air intake; Banks Monster Diesel turbo back exhaust and power elbow; Superchips Cortex tuner with the heavy tow tune installed; 35x12.50x20 toyo open country Mud Terrain tires on my 20x12 massi hulk rims; Snow Performance MPG Max water/meth kit; dieselsite coolant filtration system, Delo ELC coolant; Dieselsite Transfiltration system; Fitch Fuel Catalyst System; Up front F350 snow plow x code springs with 2 inch hangers and a Ranch Hand Legend bumper with extended shackles and extended sway bar links and dual bilstein shocks, Fox dual steering stabilizer setup going to the Dana 60 front axle, out back I have Moded B code springs with 4 inch F350 blocks and Hellwig rear sway bar = 6 inch lift, Wicked Wheel 2 (beta-testing for dieselsite); International coated bellowed uppipes from riffraff, and intake plenum inserts; high pressure oil crossover; fuel rail crossover units from riffraff; Boost relief valve from dieselsite; AIH delete Mod, CCV Mod...
Currently I am running my settings on my Snow Meth injection at MPG mode, low threshold @ 3psi, High @ 8 psi with Max at 10, one other thing I am getting my PSI reading for the Snow controller from the dieselsite boost relief valve.
