Black inside Tailpipe Jerking
Old Jan 27, 2013 | 11:23 AM
dlibson's Avatar
dlibson
45-55 is good.
Old Jan 27, 2013 | 12:09 PM
saycheessee's Avatar
saycheessee
so no one else has any suggestions on what would be wrong??
Old Jan 27, 2013 | 12:16 PM
mustang_309's Avatar
mustang_309
My guess would be something with the injectors but you need to have the DTC codes read if there are any. Without any gauges and not knowing if there are any trouble codes we will just be speculating.
Old Jan 27, 2013 | 12:17 PM
Edogsf350's Avatar
Edogsf350
No one has suggested to have the FICM checked
Old Jan 27, 2013 | 12:20 PM
saycheessee
What kinda guages are the best to get and where from? I'm tired of guessing!!
Old Jan 27, 2013 | 12:46 PM
Edogsf350's Avatar
Edogsf350
Get the scan gauge 2 at auto zone or the manny fine retailers off the Internet .
Go to the search bar type in scan gauge and there will be hrs of reading on it.
I've got one to moniter the goings on of my engine. Unfortunately it doesn't monitor fuel PSI or EGT
Old Jan 27, 2013 | 12:59 PM
mustang_309
A lot of guys on here like the scan gauge II, I like the Edge insight CTS but it doesn't monitor a few things the scan gauge does like IPR% fan RPM and some others, but will monitor EGT and you can monitor fuel pressure with the Edge EAS or you can go with the smartphone apps like dashboss for IOS or torque for android.
Old Jan 27, 2013 | 01:08 PM
Edogsf350's Avatar
Edogsf350
What year did the factory install FP and EGT Sensors on the 6.0 ?
Old Jan 27, 2013 | 01:34 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
They didn't.....
Old Jan 27, 2013 | 02:16 PM
mhoefer's Avatar
mhoefer
You have to add in the pyro in the exhaust for egt and the sender for fuel pressure to get a signal to these gauges. The rest comes from the obd2 port below steering wheel.
Drain water, into a glass jar, let it seperate, look at how much water, replace fuel filters, do you have any gelling of the fuel? Lots of water issues with these trucks only a little can ruin injectors fast. If this doesn't bring up anything then you need to start looking at FICM voltages and start up. I am thinking 50/50 it's ficm or injectors, like 4 of them if it's sounding that bad.
Old Jan 27, 2013 | 05:35 PM
saycheessee
The Pump was installed in September 2012 and the EGT has been replaced in I believe September 2011 along with several other components on that trip.
imjwm
Oct 3, 2014 04:27 PM
mark r / 019
Mar 11, 2014 10:20 PM
xaviar
Mar 4, 2014 07:42 PM
beezf350
Dec 19, 2012 09:02 PM
rotorhead
Feb 25, 2002 11:51 AM
