Anyone tried compounds?
Old Jan 29, 2013 | 07:02 PM
fordpride's Avatar
fordpride
Here ya go
http://www.atsdiesel.com/ats2/templa...029422272&c=36
Old Jan 29, 2013 | 07:33 PM
sledhead999's Avatar
sledhead999
"The small turbo charger is referred to as the high-pressure turbo charger and the large turbo charger is referred to as the low-pressure turbo charger or the atmosphere turbo charger. In a "Compound" turbo charger set up the small turbo is responsible for generating quick turbo response and rapid air flow right off idle. As the engine is accelerated from idle the small turbo begins to produce boost immediately wile the large turbo slowly starts to produce a positive pressure to the small turbo. The large turbo when matched properly should be supplying boost pressure to feed the small turbo shortly after the small turbo is making boost in to the engine or intercooler. If the large turbo charger is not matched properly it will cause the small turbo charger to stall and the low-end performance will suffer."
Cant quite wrap my head around the small turbo being high pressure and the large turbo being the low pressure turbo...
Evergreen03
Feb 10, 2019 08:13 PM
95Z71
Arkansas Chapter
Aug 24, 2008 04:08 PM
littledre1
6.4L Power Stroke Diesel
24
Aug 26, 2007 12:27 PM
LAUDY
68
Jun 17, 2007 07:07 PM
mgm5555
Feb 26, 2005 07:16 PM
