Intriguing problem
Old 01-25-2013, 08:55 PM
Forger's Avatar
Forger
Forger is offline
Intriguing problem
97 f250 dual tanks with a 460 and 4x4. My front gas tank is not working, but its not working in a strange way.
1. Went to start up truck and I got a click from the starter as if the solenoid was bad. Tried to jump same reaction, fiddled with engine ground and tried to start but wasn't turning over as if it had no fuel.
2. Switched to back tank, got the click again. Finagled with engine ground started up again. Switched to front tank, engine died immediately, however, power was still on.
Normally, I would say that this was a bad pump, but if it was a bad pump it should spit and sputter then die as if getting no fuel. It seems to be dying as if the coil stops getting power. Any ideas why that would be related to the fuel tank switch?
Old 01-27-2013, 07:49 PM
Forger's Avatar
Forger
Forger is offline
No ideas or not enough information?
Old 01-28-2013, 07:39 AM
jr32560's Avatar
jr32560
jr32560 is offline
sounds like your front pump is dead
now the clicking and finnigling with wires and the no turn over problem is not the pump
fuel does not make an engine spin as you turn the ignition key
sounds like a bad ground or bad wires on the battery
yes when you switch to a no pump issue the truck dies
no spit no sputter-you lose the pressure the injectors don't spray
Old 01-28-2013, 09:51 AM
Forger's Avatar
Forger
Forger is offline
So two unrelated problems manifesting at once. haha great and thanks.
Old 02-01-2013, 02:54 PM
Forger's Avatar
Forger
Forger is offline
Is there a separate pump relay for each in tank pump?
Old 02-01-2013, 07:15 PM
92blue on uhhhh blue's Avatar
92blue on uhhhh blue is offline
dont worry every truck i had either one tank would siphon into the other or the front fuel pump died. range is greatly decreased when all you have is the rear tank
Old 02-02-2013, 01:22 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,194 Likes on 943 Posts
No, there is only one fuel pump relay. The dash selector switch routes the power to the selected tank and also switches the fuel sender signal to the gauge.
Similar to this diagram for a 1991 truck:
courtesy of oldfuelinjection.com
Old 02-06-2013, 07:02 PM
Forger's Avatar
Forger
Forger is offline
Thanks for the diagram. Believe it or not its actually this damn engine ground that keeps giving me issues. I cleaned off the wire and the bolt on the engine itself and I still have to fiddle with it to get it to start, so I'll be buying a new one pretty quick. REdoing the entire steering system, radiator, and front axle. Ill make sure to do it then.
Crewcabber
03-24-2014 08:24 PM
joeyrsmith
11-19-2012 01:48 AM
unibody62
07-05-2011 10:03 AM
MENDI1
Electrical Systems/Wiring
02-27-2004 08:16 PM
BOAZTOBALCAIN
02-26-2003 10:18 PM
Quick Reply: Intriguing problem
