04-06 seemed to be the problem years. 03 would still be a 2v as would an 04 heritage model. Have seen problems on an 08 but it was a company truck and anything will break if you beat on it like a government mule.
Not to hyjack, but what are the symptoms of the cam phaser issues? I ask because I have the '09 5.4 with 103K on it. Seems fine. It does "rattle" a bit for a minute or two when it's real cold.
there's nothing really "wrong" with it, and the engine will run fine. If you go to a drive-thru and have your window down, it will sound like a new diesel (nice and quiet diesel) if your cam phasers are going bad, or, are bad. I had an 06 that had that issue and put another 40,000 miles on it before trading it in.
Sorry for my ignorance, but what is a cam phaser??
I'm not typing all that...Google "What is a Cam Phaser?" Never mind...did it for you...cut and paste...
What are cam phasers?
Ford’s cam phasers are specially designed, computer-controlled cam gears that have the ability to adjust camshaft position (centerline – advance or retard) while the engine is running. They are used on all 2005 and newer, Ford 3 Valve Modular engines. Since the Modular 3V engine uses two camshafts, one phaser is required for each camshaft - two cam phasers per engine.
How do they work?
Engine oil is pressure fed through a series of passageways in the cylinder heads and camshafts, then out into the cam phasers. The engine computer controls a pair of solenoids that adjusts this oil flow through a series of chambers inside the cam phaser. Located inside these chambers are vanes, attached to a free-floating central hub. The hubs are directly attached to the camshafts, and as oil is allowed into and out of these chambers, the position of the cam can be retarded up to 60 crankshaft degrees.
