350 or 500 CFM for stock 360
i think the stock 2-barrel would have been way closer to 350 than 500.
scroll all the way to the bottom:
Classic Inlines Autolite Carb's
it'll show you the CFM ratings.
granted, by '75 it would have been Motorcraft instead of Autolite, but i think the reference is still good.
I had just read that a few days ago. From searching the forum alot, it looks like most people over carb their engine. I think I would rather start small and move up from there if need be.
The only thing I would warn about on the 500 holley is the accelarator pump. Im running a 4412 (I believe those are the numbers) on my truck with a 352 overbored 30. I run a set of flowtech headers into a 2.50 pipes. The carb has a 1" spacer under it. All that being said...... when the gas pedal is pushed hard I get just a bit to much fuel and motor bogs a little. Its really bad when the cold blooded FE is cold. Im going to go to a 4 barrel manifold and a holley 600 cfm carb in the near future so I havent looked into changing the jet on the accelerator pump. I have read that it can be done. Just what Ive experinced with a holley 500. Other wise it is a great carb.
Besides, they now use EFI.
on
1 Post
Nascar can get away with it with Ports and cam ! NO in the way via intake ,valves or head ports... Give me a freakin break..My Cub Cadet has 180cfm for a 22hp Vtwin..
on
1 Post
Highboy ! look at the difference in the carbs...take an asprin and then call me in the am !!!! LMAO !! Not even the same ! Look at the thoat size and the base plate bores !! then the intake bores..then the intake on the heads ! C'mon wake thew f'up !!
My carb probably came with a 50cc pump. I have read that they can be changed to a 30 cc. I have not changed it so it is more than likely still using the 50cc. If I easy the gas pedal down so the motor doesnt get the whole shot it runs up just fine slap the pedal down and give it the full squirt momentary loss of power or a bog as I call it. When I say easy it down im not talking about pressing in slow motion just not slaping it to the firewall. Thats how I can tell that it more than likely is to much fuel.
