fuel pressure
Old Jan 24, 2013 | 09:46 PM
yorky's Avatar
yorky
fuel pressure
recently I tested my fuel pressure and got 65 psi. Now when I say I got 65 psi, that was with and without the vacuum line connected to the reg, and with key on engine off and running. Is this normal or is the reg/damper (as some call it) bad? When I throttled it up, I only had a slight drop in psi (maybe half or full pound) for a split second then back to 65.
Also I replaced my vacuum lines because of a small leak at the one dual connection, but haven't retested it since (don't recall if one of the lines from the dual connection was from the reg).
Old Jan 24, 2013 | 11:05 PM
Mikeman's Avatar
Mikeman
I'm sure someone could help if you mentioned the year and model. I seem to remember 40-45 psi being the correct value for my 4.0 Ranger and Aerostar, but all the stuff I drive is old. I would expect the pressure to change with and without the vacuum line hooked up, though.
Old Jan 25, 2013 | 01:51 PM
yorky's Avatar
yorky
its a 2000 exploder 4.0 ohv
Old Jan 26, 2013 | 08:44 AM
shorod's Avatar
shorod
Per the factory service manual, the fuel pressure spec for a 2000 Explorer (regardless of engine) is 65 +/- 8 PSI. The same pressure applies for KOEO and KOER.
-Rod
Old Jan 26, 2013 | 01:09 PM
yorky's Avatar
yorky
-Rod
thanks, the only other thing is does it matter if the vacuum line is connected to the I guess damper, the piece on the fuel rail. because when I tested I got 65 with and without the vacuum line attached, and maybe a 1 lb drop for a split second when throttled up each way also (which I'm not worried about with that small of a drop, could barely see the needle move hince the maybe 1 lb)
Old Jan 26, 2013 | 11:49 PM
shorod's Avatar
shorod
The mechanical fuel pressure regulator is there to relieve over pressure. If the system is not going over pressure (which your readings would indicate it is not) you won't notice a difference with the regulator connected to vacuum or not.
-Rod
Plowboy34
1983 - 2012 Ranger & B-Series
Nov 2, 2017 02:52 PM
RonaldD
May 30, 2013 12:35 PM
Aerostar1
Aerostar
17
Feb 19, 2007 11:03 PM
geson
Jul 17, 2004 11:08 AM
TexasGuy001
Dec 23, 2001 02:30 AM
