91 explorer with charging problems
Old May 28, 2003 | 06:27 PM
csnider10's Avatar
csnider10
Unhappy 91 explorer with charging problems
I have a 91 explorer that is having a strange problem. The charging guage is running on the very low end (around the N). I had the charging system checked and the system was not charging. I replaced the alterneator, cleaned the battery terminals and the problem persists. I have checked the fuses and they all seem to be fine.
The problem will go away at times as if there is something loose. I have noticed that when the battery light comes on when I start the car, everything will work fine. If the battery light does not come on when the car is started I have the charging problem.
Thanks for any help.
Chris
Old May 29, 2003 | 01:38 AM
ford_tr_man's Avatar
ford_tr_man
try the battery cables
Old May 29, 2003 | 08:52 AM
csnider10's Avatar
csnider10
I've checked the cables and they seem to be fine.
Old May 29, 2003 | 12:05 PM
stubborn1's Avatar
stubborn1
Have you traced the wiring down to the starter? Sometimes this wiring can get frayed and ground out against adjacent metal.
Just another idea for something easy to check.
Old May 29, 2003 | 09:08 PM
ford_tr_man
even if they look good it can still help to change them
Old May 29, 2003 | 09:11 PM
csnider10's Avatar
csnider10
Thanks, I'll check them more closely in the morning.
Old Jun 2, 2003 | 08:52 PM
csnider10's Avatar
csnider10
Thanks for all the help. I found that the problem was that hte alternator I bought was bad out of the box. Once that was replaced everything is working fine.
Chris
Old Jun 2, 2003 | 09:16 PM
kev100's Avatar
kev100
test post
Robber80
Dec 12, 2018 05:33 PM
ddg21snipe
Aug 18, 2005 12:28 PM
kochy54
15
Apr 21, 2002 05:31 PM
