Hey, I've got a 98 Ex Sport, and neither the front nor the back washer pumps spray. I can't even hear the motor kicking on. Is there one pump, or two dedicated ones for front and back. And is this something common or should I run to the junkyard for some washers. Thanx
Funny, I just checked mine today in my '98 Exploder . When i press for water I get none... But I did take of the plug at the pump and ran 12 volts to it and it does work. (is there a seperate pump for the back? I don't know I'll check tomorrow). This means the switch is bad. I get wiper but no water. There's a post about how to fix the contacts in the switch but i didn't understand how to get into the switch. I'll find the post, reply and hope to get us an answer.
