1981 E-150 heater core replace
Old Jan 24, 2013 | 08:23 AM
turbogus's Avatar
turbogus
Hi gang form Oregon~the shower me state. Well, just as my Jeep is going into the shop "Easy Bake"
decided to start leaking at the heater core from the smell of it. I've done a heater core on this van about 12 years ago but the manuals I have fail to detail removal installation. As I recall it was a bugger to get the plenum out of the cab and there were other difficulties that by now I have forgotten. Does anyone have a procedure, know the tricks and traps, or know of an accurate resource?
Thanks and a lift of the lynch lid.
Old Jan 26, 2013 | 09:10 AM
turbogus's Avatar
turbogus
WOW! The heater plenum came out like a snap! This has got to be the easiest heater core replacement of any car/truck/van I've ever done (the toughest? my '78 Jeep Renegade)
The TRAP~Locating a CORRECT Brass/Copper heater core. Tried the local NAPA, and while they didn't have the next town's NAPA did. While on the phone I asked Jim (NAPA) to verify that it was brass/copper and they affirmed. After work went to Albany and...... Made in China aluminum that was smaller and the hose extrusions were not correct.
Had a similar issue with a water neck for my AMC 360 (Jeep), THREE tries at NAPA yeilded three made in China water necks EACH differing in the angle on the radiator hose extrusion, none of which was correct! Ultimately had to got to the boneyard and pull one from a 401.
Does anyone have a resourse for this BRASS/COPPER heater core for;
1981 Ford E-150 w/4.9L (300ci) no AC?
Thanks and a lift of the lynch lid for yours responses!
Old Jan 27, 2013 | 03:14 PM
turbogus's Avatar
turbogus
Well, it turned out that Angie at O'Reileys ordered the two available brass/copper cores available, they had to order in but it was same day shipping (likely from Salem or Eugene) the first being three inches longer (HD heater) and would've fit but I would've had to modify the bracket 1/2 inch with plumber's tape that I did have at home (got some at the depot). Ultimately had to relocate a hole in the plenum for a tighter fit, previous owner used windshield rope (remember that stuff?) to hold fast the heater core in it's loose end bracket. O'Reiley's had no problem with the exchange as I only test fit the larger core and it didn't get crummy. SO far so good though. One thing about this Ford heater plenum removal and heater core replacement, it was a damsight easier that the three day project on "Black Betty" my '78 Jeep Renegade.
turbogus
Feb 2, 2013 09:50 AM
dohc_chump
27
Sep 28, 2010 03:04 PM
Andy_H
Jun 12, 2007 12:18 AM
73Riviera
Sep 8, 2006 02:08 PM
don_79f250
Dec 13, 2004 07:32 PM
