pulling in overdrive
Old May 28, 2003 | 05:24 PM
mekons0's Avatar
mekons0
Question pulling in overdrive
I have a 2001 psd with the 6 speed manual, supercab, 4x4. I now have a fifth wheel that weighs about 5500 lbs. Is it ok to pull in od? It has lots of get up & go but will the transmission hold up or will my exhaust temps get to high. I usually run Kansas, about 65 mph, 1900 rpm with 3.73 gears. We do have strong headwinds from time to time (25-35 mph).
Any suggestions?
Old May 28, 2003 | 10:03 PM
johnsdiesel's Avatar
johnsdiesel
Tow in OD and take it out if it bogs down. You don't have to worry about towing in OD because it's a manual transmission. The main reason for taking a vehicle out of OD when towing is to avoid "seeking" in and out of OD with an automatic. Tow in OD and save the money for more fuel.
Old May 29, 2003 | 11:40 AM
mekons0's Avatar
mekons0
Thanks. I hadn't heard much about not using overdrive but another DODGE man said that his has a planetary overdrive setup and the bearings are too light. Nothing that $2500 dollors wouldn't fix. He now runs in high whenever he pulls. (About 55 mph)
Should have bought a Ford.
