What would cause low vacuum?
Old Jan 23, 2013 | 05:58 PM
tasboj's Avatar
tasboj
Hi guys I went to a carburetor shop today to have my Holley 2BBl idle/air mixture adjusted, the mechanic guy said vacuum is low at 15Hg is this bad, what would cause low vacuum. I have a stock engine,cam,lifters,everything is stock, he also said that the idle screw , out is lean/ in is rich on this Holley 2bbl, because I thought it was the opposite in is lean, out is rich.
any advice is appreciated thanks
Old Jan 23, 2013 | 09:59 PM
crazed87bronco's Avatar
crazed87bronco
Have you looked over all your vacuum hoses for any cracks or leaks? They can get old and brittle might have a leak. Also check your timing that can give you low vacuum problems also
Old Jan 23, 2013 | 10:37 PM
orich's Avatar
orich
Timing maybe need to be set. Dizzy Vac. advance maybe sucking air. Most guy never check these when doing a tune up. Tired old motor in need of a valve job..
just for starters..orich
Old Jan 23, 2013 | 11:13 PM
HIO Silver's Avatar
HIO Silver
What 2V Holley is on the rig? Look up the carb specs/tech info (Visit Holley's tech site at Holley Performance Technical Service Department and look up the resource docs) and evaluate his claim on the truthmeter. If I found out he's lying, then he is not to be trusted EVER again with my business.
As a great American once said: "Trust, but verify" - Ronald Reagan
Old Jan 23, 2013 | 11:47 PM
Redmanbob's Avatar
Redmanbob
In is lean/ Out is rich
The process is simple as to the A/F mixture screw method. The screws are moved in to lean the mix (cutting the fuel to air ratio) & (out to add fuel to the A/F ratio) richening the mix. As the mix leans up you will see a rise in vacuum, richen a lower. Too far in will choke out the motor, too far out will result in a low vac rich burn. A good airtight engine should OEM setting without any faults to the system will be 17-23hg imo. "Assuming that all the parts are working correctly in harmony" Timing, vac advance diaphragm leak, break booster, etc... low vac.
diagnosis via web/posts is futile... hope this will help.
How to Use and Interpret a Vacuum Gauge
Old Jan 24, 2013 | 04:25 AM
willowbilly3's Avatar
willowbilly3
Yes, holleys can be backwards. Timing or a tired engine are the 2 biggest reasons for low vacuum. But some engines just carry more than others too. 15 is a bit low, was it the needle steady? I've had perfectly healthy engines that wouldn't make more than 17, and even though they say the range is 17-23, I have never seen an engine that could pull 23, or 22, few even that did 21.
BTW, get a vacuum gauge of your own, it is one of my most valuable tools and one of the first things I grab when diagnosing.
Old Jan 24, 2013 | 11:22 AM
tasboj's Avatar
tasboj
Thanks willowbilly3 for the response,I do have a vacuum gauge and it only reads 15Hg and the needle is steady no flikering no matter if I advance time or play with the A/F mixture,my compression is 135psi all around no smoke, to me that sounds like a healthy engine.
You know I watched the guy adjust the A/F and wen he turned them in nothing happened, but wen he turned them out it would start to stumble and thats wen he said this idle screws are opposite for adjustment this is the list #7508-1and this # under 0488.
this # is not listed in the holley website what I have found is that this is an oem carb for Fe's
Old Jan 24, 2013 | 12:00 PM
tasboj's Avatar
tasboj
HIO I called a holley tech because I could not find info on the web site and he confirmed what the mechanic said about the idle screws,
in is rich,
out is lean,
LIST # 7508-1
0488
This is an oem replacement carb, not a performance carb, he called it "ECONOMASTER",270 cfm with a reversed adjustment for A/F mixture, So I think I just found a shop I can trust sense the guy new what he was talking about
Old Jan 24, 2013 | 02:10 PM
tasboj's Avatar
tasboj
in is rich,
out is lean,
LIST # 7508-1
0488
This is an oem replacement carb, not a performance carb, he called it "ECONOMASTER",270 cfm with a reversed adjustment for A/F mixture, So I think I just found a shop I can trust sense the guy new what he was talking about.
How do I post a pdf file I have some info I want to share.
Old Jan 25, 2013 | 01:27 PM
FECruzer69's Avatar
FECruzer69
What is your initial timing set at? How many degrees BTDC?
Old Jan 25, 2013 | 01:53 PM
tasboj's Avatar
tasboj
Its around 20* ,if I try to set 6* or 12* the vacuum drops, and if I go above 20* it starts to ping, what do you think about recurbing the distributor?
At 20*BTDC 15Hg is the highest vacuum I can get,anything less than 20*BTDC vac drops,my compression is 135psi all 8 cylinders.
Old Jan 25, 2013 | 03:02 PM
tasboj's Avatar
tasboj
HIO this is what I found about 2v holley 7508-1
http://oldholden.com/ohfiles/Holley%...t%207508-1.pdf
Old Jan 25, 2013 | 04:33 PM
willowbilly3
I am wondering a little about how far the throttle butterflys are open at idle, or if you have a vacuum leak. If it doesn't respond real well to idle speed adjustment, maybe there's something we're missing. If the throttle plates have to be adjusted (idle speed) too much open to keep it running, the vacuum would be low and the response to idle mixture would be less noticable.
Old Jan 25, 2013 | 06:07 PM
tasboj's Avatar
tasboj
Wen you say throttle plates adjustment,this is done with the curb idle screw on the accelerator linkage right.
Old Jan 25, 2013 | 06:54 PM
Alex from GA's Avatar
Alex from GA
That's what I understand he said. I want to subscribe to this thread is why I'm replying.
