Offroad & 4x4
axle id
Old May 28, 2003 | 04:30 PM
therigwelder's Avatar
therigwelder
axle id
I have a 77 f-150 4x4 and i need to know what axle i have in the front and what type of transfer case i have.the front axle is 9" and has a 10 bolt cover, the transfer case is coupled to a 4 speed standard.
also where can i find a parts breakdown for the fore mentioned parts
Old May 28, 2003 | 04:42 PM
RRMike's Avatar
RRMike
axle id
The front should be a Dana 44. If so it has a 8.5 inch ring gear not a 9" ring gear. The t-case should be a np 205.
bronczilla's Avatar
bronczilla
axle id
Heres a site to ID the T-case. Most likely its a NP205 or NP203.
http://www.truckpulls.com/Transferca...mage_Index.htm
F-150s have a D44 front HP or LP.
Old May 28, 2003 | 11:26 PM
RCrawler's Avatar
RCrawler
axle id
Like everyone said, it is a HP Dana 44 front end.
I believe that all the 4 speed equipped trucks had part time 205's in them. Two easy ways to identify: Shift pattern
205 have 2H, 4H, N, 4L
203 have High, Hi Loc, Lo, Low Loc
Also the 205 has a approx. 2" round cover on the back with 3 bolts.
Jason
Old May 29, 2003 | 03:57 AM
John Pen's Avatar
John Pen
axle id
How about axles on a 74 '250..Where would i start to figure out ?
Old May 29, 2003 | 12:27 PM
RRMike's Avatar
RRMike
axle id
Low pinion dana 44 front and dana 60 rear most likely. Np 205 case in this also but a divorced version.
Old May 29, 2003 | 10:45 PM
RCrawler's Avatar
RCrawler
axle id
Could also be a Dana 24 transfer case.
Jason
