Installing Vibration Isolator Kit
Old Jan 23, 2013 | 03:05 PM
makthenif's Avatar
makthenif
If anyone has installed this kit and has any tips or help suggestions, please reply. I bought the kit for my 2002 Expy from Arnott and hope to mount them soon. Thanks
Old Jan 23, 2013 | 10:41 PM
5.4T's Avatar
5.4T
Take the Wiper fluid tank out Much easier!!! that's about it....I could never get the air line off tho, but you really don't need too, I thing I could not understand is the kit comes with 3 Rubber insulator but the Compressor has 4 Holes....one just empty from Factory, I assume........
P.S. I had mines for a 1year and 4 months and I have to either replace the isolator or the compressor because it sounds like a air tool again... DO you know if you can oil the compressor? Or I Think its my isolators again!!
Old Jan 24, 2013 | 08:31 AM
makthenif's Avatar
makthenif
You have to replace the isolators again. this is my second time.
Old Jan 24, 2013 | 09:59 AM
68bluebeast's Avatar
68bluebeast
What makes them go bad so quick? I need to install one on my 01 navigator, it sounds like crap!
Old Jan 24, 2013 | 11:50 AM
alloro's Avatar
alloro
If I had to guess I would say...vibration.
Old Jan 24, 2013 | 04:43 PM
68bluebeast
Arnott® K-2103 - Lincoln Navigator 1998-2006 Suspension Air Compressor Isolator
Are these what you bought? couldn't I just go to a hardware store and buy some ruber bushings? Is that all these are or are is there somthin special about them?
Old Jan 24, 2013 | 08:18 PM
5.4T's Avatar
5.4T
they have thread in the middle
Old Jan 24, 2013 | 10:20 PM
makthenif's Avatar
makthenif
yes
https://www.arnottindustries.com/par...d3_gid209.html
Old Jan 24, 2013 | 10:21 PM
makthenif's Avatar
makthenif
yes
Old Jan 25, 2013 | 02:47 PM
bucktaylor's Avatar
bucktaylor
Pulled the washer fluid tank as well... used a few socket extensions to get down in there.
To Disconnect the air lines (if needed), I pushed in the little ring with a flat screwdriver, while pulling the air lines. Mark or note which hose goes where.
Old Jan 25, 2013 | 05:37 PM
aft2005exp's Avatar
aft2005exp
In case there is a better place to post this question, rather than here, I apologize in advance.
I have a '05 EXP EB 4x4 131k miles, and it is time to replace the suspension air compressor. Does anyone have any advice on which after market compressors are a better choice? Does anyone know if one manufacturer is quieter? Better fit?
Any advice is GREATLY appreciated..
Old Jan 25, 2013 | 06:31 PM
bucktaylor's Avatar
bucktaylor
Check with Air Suspension Parts & Conversion Kits for Most Makes & Models (HP) | Americanairsuspension.com , I remember them being recommended by many on this forum.
Old Jan 25, 2013 | 10:41 PM
aft2005exp's Avatar
aft2005exp
I'll check it out thanks !
Comanche1
40
Feb 18, 2014 05:42 AM
old blue beast
Jan 26, 2013 09:07 AM
jsmahan
Feb 19, 2012 10:19 PM
DeeDubz
All Things Towing
Feb 17, 2012 11:44 AM
lowtrkn2k
24
Sep 11, 2008 03:34 PM
