Sponsored by: Real Truck
Multiple coil pack failures?????
Old Jan 22, 2013 | 07:20 PM
tibbytom's Avatar
tibbytom
Took my 97 Ford chassis motorhome in for service. They recommended changing the plugs, along with cyl 6 coil pack which had coded misfire. After replacing cyl 6 coil pack and all plugs the RV ran great at low RPM, but under throttle the engine was misfiring. The computer showed various cylinders. Turns out 4 more coil pack needed to be replaced to make it run right. My questions is, what could have caused 4 coils to go out at once??????Any ideas? Thanks.
Old Jan 22, 2013 | 08:12 PM
Little General's Avatar
Little General
Water could do it. My 2006 F350 5.4 had no issues until the battery went dead and I left the hood cracked with the batter charger sitting under it out of the rain. Anyway, when I started it up to run into town, I had a #7 coil pack out. Stopped at a local tire store and their mechanic pulled all 4 packs on the drivers side and blew them out with an air gun and cleaned the corrosion from the rain pooling in the plug holes. Problem solved.
trike1946
Dec 10, 2017 12:42 AM
tackelberry88
1997 - 2003 F150
Jun 16, 2010 11:33 PM
mrpiggy52
1997 - 2003 F150
Feb 3, 2005 11:35 PM
tofer76
Electrical Systems/Wiring
Oct 16, 2004 11:58 PM
